hey guys im pretty new to these forums but i have just about completed this lil project that use are all doing and it is quiet easy all i did was tape of the letter and snad the plastic and paint it i happend to have some spair paint from my body kit laying around. for the bak of it i just used a stanley knife and a hand help haksaw blade to cut the bak strip out u will see there is a 400mm section in the bak of it ther eis a plastic line at ech end of it u will no wa ti mena when u see it just cut down them and along the sides and pop it out. then for the lights i just went and bought 2x 200mm red led lights from autobarn or the like and gled them to the baking that i cut out all i had to do to fit thes was slightly stager the leds so i didnt have a big gap in the lights in the middle but it looks wuit good u can tell that the 2 lights are stagered but i dnt mind then all i have ot do now is glue the bak peice bak into it and put clear over the top of my paint. i wired them into my parkers looks awsome. hope that may help anyone whith there project.
damn you are stingy with the letters you use for words all with the ech, thes et al .. saturday morning sickness is what it brought about :yes::P:)
  • Replies 166
Posted Images
yeah LED's dont blow that often...
i've ordered 2 new S1 facias... i came up with a design idea that no one has done yet... and it could possibly save people time and money... *oooooohhh secrets :P*
Please tell! :P :laughing-smiley-014:
lol sorry so wear not all perfect but u get wat i mean
Yeah I was straining my eyes a bit reading that. :):):P
Got any pics of how it turned out? Would be interesting to see.
hey well i havnt got any piks just yet but i will get there soon. i just sorted out the leds again cos it looked avergave having the leds stagered so i modified the 2 led strips and made it fit in one straight line with a lil bit of cutting and it turned out good ill get some piks up soon
That looks awesome! I've got my series 1 panel, but I don't know what to cut the back out with. I'd like to cut out a perfect strip from end to end along the back and then re-seal it. Got any ideas on how to do this neatly?
stanley knife and patience
ok heres a hard question for you al, im not familiar with 33 2drs (ive a 4dr) or series numbers, neway i have painted the letters on my car and am wondering, on a 4dr or 2dr can u get the plastic around the letters to light up?
u painted the letters? why?
Edited by traman18
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
