The Entry Forms and Supp Regs are still not complete, but the event looks to be proceeding.
This post will be update the minute the forms are available.
Remember that Sandown always draws a big crowd and is always a great day out.
At this point in time there will be Driver Training run in conjunction with the usual sprints, so post up if you are interested in doing Driver Training on the day.
The day will once again be run with a 75db noise limit so ensure you have taken reasonable measures to ensure your car complies (Yep no more gate from me :) )
Driver Training
Do-Luck
femno
thebuzz
tangles82
Either post up or PM the person regarding their availability to be your instructor from the following list:
- Scotsman
- Belsil80
- Roy
- JAGR33
- Aaron34 (may not be attending as not entered)
- Snowman (though may be busy getting his head around the frexh car)
Entry_form_Sandown_25_Apr_07.doc
Supp_Regs_Sandown_25_April_07.doc
https://www.sau.com.au/forums/topic/163996-wrx-sprint-round-3-sandown/
  • Replies 237
Posted Images
Also, if your car is off the road or you are not sure about running for the first time. Email me at [email protected] if you would like to help as an Official for the day.
We always need flag persons and its a great way to get close to the action and see how the days are run. On top of that you will get a free lunch and drinks and every competitors thanks for helping with the running of the day (No small feat)
There will be suitably experience people supervising/supporting you on the day so it is a great introduction to what the flags mean and how the day runs. No need to worry about not knowing what to do...if i can do it then any monkey car. :)
Ok, wiring up all the channels on the data logger this Saturday. A fresh sump of oil and out comes the pin for Sandown.
Its 1:23 or bust...but will so piss my pants with laughter if i knuckle out a 1:22! :)
And of course, im still saving for a holiday so too tight to buy my onw camera. Anyone kind enough to lend me one again on teh day?
Its 1:23 or bust...but will so piss my pants with laughter if i knuckle out a 1:22! :wub:
DUDE! I'm almost GLAD it won't be Me trying to hang-on to that thing down into Dandenong Corner !
Good luck to everyone all the same! (I'll still be broke then, but an outside chance to come down & lend a hand)
It looks worse then reality. At least its predictably low on grip :glare:
:wub: Sandown
Updated first post. GIDDY UP! Roll on the good times :stupid:
Standard currency... who wagers a case that i can do a 1:21.999999 :(
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
