The A048's are the worst for heat cycles. If they are going to be used for regular track work as well they only have a good 10 or so heat cycles before they really harden up. This fact makes them probably a longer lasting street tyre however. I've used one set and won't use them again.
The Dunlops seem to be the best but are $$$ which is why I use the RE55's which are pretty awesome at everything. The Toyo's have amazing grip from cold compared to the others but not as much grip when hot.
  • Replies 40
One other point people may like to note is that the RE55's (Bridgies) make an absolute bucket load of noise on the road. The Toyo's (RA1's & perhaps the 888's) are, by contrast, civilised.
Yeah the road noise really gets to me at 6am drives to Winton :D .
I wouldn't use it on a daily driver, especially before the tyres warm up, the grip is worse than my street tyres.
Edit: Im using RE55s.
Edited by Yawn
every tyre 'heat cycles' I think what you actually want to know is does a tyres performance drop off after a number of heat cycles and the answer is yes, all semi-slicks are affected by the number heat cylcles they are put through. some worse than others, but they all are in some way.
A048's are the worst for performance drop offs after heat cycles. They really do go rock hard.
The Toyo R888's are excelent for road noise compared to the others. I'd use these if the car was seeing more street time than anything or if the motorosport I was doing was primarily auto-tests / hill climbs.
But for a track day tyre I'd use the DZ03's if I could afford them. But I can't so I use the RE55's as they are the next best.
Do you remember which compound of A048 you used, Snowman?
was it Medium (M) or Medium-Hard (MH)?
yeah. i used to use the ute ones. we have a large stack of them all with abot 1.5-2mm left on them. generally this amount lasts about 2 weeks of normal driving up and down the m2 before they are completly smoth.
pretty scary but. not bad in the rain. but at 300+ a tyre its just not worth it. thats what the spare rims with propper track rubber is for :down:
gordon should have been happy then, thats 3 categories in nsw using them as control tyres. Shame they suck - utes used to run on basically a road tyre compound so its not wonder they are going better now - but the dunlop dz03 and bridgestone re55 are still at least a second quicker.
Haven't tried the toyos myself but they are getting a good wrap atm.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
