So the way the wheels work what kind of lag would you expect to see from an A/R .82 on a HKS 3037 or the garrett twin GT3071R ...
I would say it wont start to really pull until 5,200rpm. Because thats a large turbo for a 2L dont be afraid to go smaller on the exhaust side. Remember it has a large turbine wheel.
For instance i run about a 0.73 exhaust housing on my turbo and my wheel is a bit smaller. My setup is a bit of a fluke in that it works so well. So with a GT30 based turbine i would happily use a housing in the 0.6X range for the little RB20. The i would expect it to really pull at about 4,500-4,650rpm provided it is tuned and set up well.
Thanks for the help Roy i get ya now :P .63 would prob be the best option for it then i think 5k is a bit too laggy... lol 4-4.6k revs is ok but any more than that its kinda waiting too long fora street car/drift.
Hey guys,
Just got the pics of the block after coming back from being machined out to 83mm Bore
Walls are still pretty thick so there doesnt look like any worries there. We are waiting for the Eagle rods to come back from being bushed to suit the 20mm pin, once they come back we can mock it up and check the compression, Most likely we will have to send the clock away again to be decked.
I have been also looking at paulr33 powerfc mod to use as the ecu for the build.
Cheers
Cameron
  • 3 weeks later...
this is exciting for me!!! i just stuffed my rb20det... either warped head or the head gasket blew.... or what ever else could be the cause of my 3rd cylinder to be full of coolant. So im trying to decide to rebuild it to rb24 or get a 30det.....
Cant wait to see the results!!!
Thats not good to hear dude, Rb30 will be very torque happy, rb24 is different thats why i went that path
The bottom end should be together in the next fortnight, so i will post some pics up when thats done, to date total cost of the engine is around the $6000 mark with ecu, plenum, fuel rail to come.
I have just fitted the new exhaust system to the car Greddy PEII cat back stainless system
Edited by murrayis
Its hard to say how much its all cost as this project has been going since december, so i will try list the parts
Pistons $1500
Rods $750
HKS cams $880
HKS Cam G $320
N1 Oil pump $430
N1 W pump $350
Block-Head $400
Valves $1100
ARP Head $130
ARC bearings $170
Injectors $660
RB26 Crank $450
Tomie gasket $350
Rod rebush $321
Machining $360
Est Total without labour $8171.00
There just the rough prices of all the items to give you an idea of the build so far to date
Edited by murrayis
Not sure on the part numbers for the water pump as i havent seen it yet, and yea might as well do it properly the first time, because it will cost more if you blow a rod and have to start from the block up again.
  • 4 weeks later...
Well just an Update.
Engine progress has slowed down atm because we are waiting for rings for the pistons to arrive from Melbourne, Also getting some ACL race bearings.
But I am also looking at selling my turbo setup as its not going to be anywhere need large enough for the engine build, If anyone is interested it consists of
Garrett 2876R .86 Rear
Low mount manifold modded to suit this turbo
Custom Dump pipe
Braided oil feed line
Speedflow connections
Oil drain, Water feed and return lines
I am looking for between $2000 - $2200 for the lot in Brisbane
On another front i got a lil bored on the queens birthday weekend so i made myself a new guage setup, its a lil rough but doesnt matter as its goign to be covered when the interior gets done.
I am still trying to find/decide on which ecu to go for, i am thinking of giving Adaptronic a try i have heard many good things about them and what features they have for there price.
i have seen (turbo CRX) and heard quite a few good things about the adaptronic (as a budget alternative) too, i may try to get hold on one to have a play with. Let me know how you go.
Ive driven an RB24DET (stupidly expensive tomei RB24), and it definitely still feels like an RB20 to drive. Even with only 230rwkw (maxxing the turbo), it is still a nugget below 4000 (due to RB20-ness, not turbo lag). Rev limiter is set to 9000, but runs out of puff by 7500.
Im interested to see how this one drives. After spending $20,000 on his setup, my mate says he would have been much happier with stock RB25 with some basic bolt-ons.
An update, Started designing a plenum for the engine, drew it up in cad and its currently at the laser cutters being cut out of 4mm alloy
Making it out of 4inch tube and some cut to size plate, pretty simple yet hopefully should be effective
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
