the inside diameter of the stock runners is 39mm and average spacing of 95mm center to center, there not all the same apart from center to center, you cant see it from the drawing but there all measured within 1mm plus i am going to add some velocity stacks that will be able to attach to the exsisting flange.
Read complete thread and seen no mention of provision of clearance cut on bottom of bores to make sure top shoulder of rod does not hit on bottom of bore.
Not seen on image of bottom of block either so do you know if you have to do this?
It will become obvious on you first dummy fit and try to turn the crank slowly to see if you have the required clearance.
This is definitely done on the jap engines I have seen and it was mentioned in the Zoom 2.4 build up.
Good luck with it and hope it makes your target RWkW reliably! ;)
Hey guys,
Thanks for that, and yes was well aware of it but thanks for the heads up. When we did the dummy fit up, everything cleared fine 3 - 4mm clearence but we have ground some extra meat away just to be safe :(
Aighty, wellz we are having some problems finding the rings to suite the pistons, we didn't get them with rings with the pistons, and now that we have requested them they said can't do.. so we are stuck with pistons and no rings, this is the only thing stopping it all going to gether and being put in the car.
On another note a few people and pm'd asking for pics of the car its going into.
The Interior is a bit of a mess but its in the list of things to do, after the engine work etc is all done and complete
got any pics of the drivers side rear 1/4>>?? mine has some slight damage and was considering a kit like that, just wondering how is comes up to fuel filler. Also bit of noob with skyline features (silvia man) and was wondering. Are those 4 door taillights or did some 2 doors come with them? If they are 4 door lights.. how u fit them?? Just new rear bar n boot?
goodluck with ur engine biuld up.
cheers
cheers
Hey,
They are 2 door lights, as for the kit its a Final Konnexion genuine kit from Japan, through jetspeed. I will try get a pic of the drivers side rear for your tomorrow.
As for the rings,
Does anyone know the measurements of the rings etc? the pistons are made by ROSS
Cheers
Cameron
You cut the intake runners how short? this thing is going to have even less down low than a stock RB20! We have spoken previously about plenums dude, I'll just remind you my mates' RB30DETT is making 460rwhp through a STANDARD RB25 plenum and throttle body.. good luck with the design and hopefully you don't lose too much torque or lean any cylinders out :(
Well put the car on the dyno last night to fiddle with the boost and AFR currently cars runnign a chipped mines ecu, and we wound the boost upto 1.15bar last night to test the timing and also to find a leak in the exhaust manifold, see the link below can you identify where the leak is lol
Dyno Video
  • 4 weeks later...
Just a quick update.
Well Finally for ROSS pistons in the USA to organise my piston rings form Total Seal in Calafornia, They where posted monday, so hoping they will be here begining of next week.
Also i took the adivice of a few people and sold my Garrett 2876R setup, and today I received my new Garret GT30r, and also along with my new highmount manifold.
Just awaiting a few missing parts out of my oil & water line kit from GCG to arrive hopefully tomorrow and the turbo will be bolted upto the car
So far its coming along pretty smooth just a couple of hickups along the way but they where expected
Cheers
Cameron
What are the specs on the GT30R, as i thought the GT30R was meant to have the ported compressor cover?
Looks great though...also, if you are going to run that shiny nice manifold long and hard you should consider some shielding/wrap/ceramic coating etc. There is a lot of wiring and hoses around there that dont like heat. Also, its expensive but if you are running ahigh mount manifold and turbo then its worth the effort to get stainless steel braided teflon line and throw some of the red heat sheathing around it. I tried a few different hose types and installs and after a few heavy track days the oil return line showed signs of fatigue and drama. So went the whole hog 3rd tim eround and countless track days and thrashings later never missed abeat. Whislt plenty of other ppl at the track with high mounts have suffered similar fate to my earlier attempts.
But looking good, keen to see the results :)
Yea i will be heat wrapping the dump pipe, and most likely the manifold, also the oil return i was going to wrap in something to keep it safe.
last thing i want is a fire lol
The oil return line i have says its flame resistant lol but yea i will look into getting a steel braided teflon one :banana:
On a good note, rings cleared customs last night, after sitting there for 2 days but of thought they where some sort of hardcore substance
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
