I love your loyalty to this project. I am not selling my RB26 bottom end now. :devil:
lol Thanks... its been 2 years in the making so no point giving up on it now..
Doesn't that tell you something ??
Yea I put it down to us increasing the oil clearance this time by another ½ a thou, and the fact when I tried it last time it was after It had spun a big end and a main bearing.
Anyway, I spent today doing as much as I could in the 36 degree heat! I spent a good 2 hours cleaning out the Sump and Head, I couldnt believe the size of the bits of bearing the I got out of the sump, I ended up filling it with water and putting a few welding magnets in the water to pickup all the small particls and large flakes a bearing. The head took the most time as I didnt have the tools at home to remove the valves so it flushed it slowly cleainng out all the oil and any small traces of bearing I could find... which was only 1 or 2 specks.
I installed the Sump, Oil pump, Rear Main Seal, Exhaust manifold, Turbo and the Head today. I held off with the water pump due to a couple of the bolts looking a little worse for wear I shall pickup some replacments from nissan this week.
Anyway heres a couple of picctures of where I am upto.
post-23119-1235886691_thumb.jpg post-23119-1235886579_thumb.jpg post-23119-1235886867_thumb.jpg
Edited by murrayis
I have been looking over my figures for the head bolts of what I had written down a year or so ago, can somsone confirm these for me.
1. Tighten to 22 ft/lb
2. Tighten to 80 ft/lb
3. Loosen bolts completely to 0 ft/lbs
4. Tighten bolts to 22 ft/lbs
5. Turn bolts 85-90 degrees clockwise with an angle wrench, or tighten to 76-83 ft/lbs when torque wrench is used.
From looking over the nissan manual these appear to be the rb26 standard torque settings, and ARP recommeneds 109ft/lbs as the final figure is this tru for the rb20 also?
I am using ARP studs for the head.
85ft/lbs with moly lube will be sufficient.
Thanks anyway, The head is already bolted down and studs have 30w on them. I used the last of my molly lube on the ARP rod bolts.
its generally 20-30 more ft/lbs when using 30W oil for that size stud...so 109ft/lbs sounds like the right torque for 30W oil.
Edited by DiRTgarage
  • 5 weeks later...
No updates really...
The engine is sitting in my garage while I contemplate If I should do a external oil pump setup on it or just a billet pump.
The clutch is off at Jim Berry's being rebuilt so once I work out whats going on there It will be back in and running again..
Could always drysump it :(
Any ideas what I should do?
Edited by murrayis
  • 5 weeks later...
Nothing much to update, Spent last Sunday putting the engine back in the car hat a mission it is to line the gearbox up with the engine! I wont be doing that again in the car.
Today I was planning on getting it started etc so got all the wiring done, water and oil lines hooked up radiator and starter motor in... put 7 ltrs of oil in and started to fill the radiator and my feet were getting wet! Somehow I have lost the plastic bung out of the radiator I suspect one of the dogs as picked itup as a chew toy like they have done with the silicon tubes.
So I am on the hunt to find a new/replacement bung for the ASI radiator, I have emailed ASI so hope I can get a replacement from them.
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
    • Not in any way aroused by any of those, except maybe the big AMGs. And that would break my never a Euro, ever, rule.
