I love your loyalty to this project. I am not selling my RB26 bottom end now. :devil:
lol Thanks... its been 2 years in the making so no point giving up on it now..
Doesn't that tell you something ??
Yea I put it down to us increasing the oil clearance this time by another ½ a thou, and the fact when I tried it last time it was after It had spun a big end and a main bearing.
Anyway, I spent today doing as much as I could in the 36 degree heat! I spent a good 2 hours cleaning out the Sump and Head, I couldnt believe the size of the bits of bearing the I got out of the sump, I ended up filling it with water and putting a few welding magnets in the water to pickup all the small particls and large flakes a bearing. The head took the most time as I didnt have the tools at home to remove the valves so it flushed it slowly cleainng out all the oil and any small traces of bearing I could find... which was only 1 or 2 specks.
I installed the Sump, Oil pump, Rear Main Seal, Exhaust manifold, Turbo and the Head today. I held off with the water pump due to a couple of the bolts looking a little worse for wear I shall pickup some replacments from nissan this week.
Anyway heres a couple of picctures of where I am upto.
post-23119-1235886691_thumb.jpg post-23119-1235886579_thumb.jpg post-23119-1235886867_thumb.jpg
Edited by murrayis
I have been looking over my figures for the head bolts of what I had written down a year or so ago, can somsone confirm these for me.
1. Tighten to 22 ft/lb
2. Tighten to 80 ft/lb
3. Loosen bolts completely to 0 ft/lbs
4. Tighten bolts to 22 ft/lbs
5. Turn bolts 85-90 degrees clockwise with an angle wrench, or tighten to 76-83 ft/lbs when torque wrench is used.
From looking over the nissan manual these appear to be the rb26 standard torque settings, and ARP recommeneds 109ft/lbs as the final figure is this tru for the rb20 also?
I am using ARP studs for the head.
85ft/lbs with moly lube will be sufficient.
Thanks anyway, The head is already bolted down and studs have 30w on them. I used the last of my molly lube on the ARP rod bolts.
its generally 20-30 more ft/lbs when using 30W oil for that size stud...so 109ft/lbs sounds like the right torque for 30W oil.
Edited by DiRTgarage
  • 5 weeks later...
No updates really...
The engine is sitting in my garage while I contemplate If I should do a external oil pump setup on it or just a billet pump.
The clutch is off at Jim Berry's being rebuilt so once I work out whats going on there It will be back in and running again..
Could always drysump it :(
Any ideas what I should do?
Edited by murrayis
  • 5 weeks later...
Nothing much to update, Spent last Sunday putting the engine back in the car hat a mission it is to line the gearbox up with the engine! I wont be doing that again in the car.
Today I was planning on getting it started etc so got all the wiring done, water and oil lines hooked up radiator and starter motor in... put 7 ltrs of oil in and started to fill the radiator and my feet were getting wet! Somehow I have lost the plastic bung out of the radiator I suspect one of the dogs as picked itup as a chew toy like they have done with the silicon tubes.
So I am on the hunt to find a new/replacement bung for the ASI radiator, I have emailed ASI so hope I can get a replacement from them.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
