Does anyone know where I can get -10 black braided line? doesn't have to be anything special it's just for the breather lines.
I have found Pro Lite 350 Hose Has anyone had any dealings with this? Or know a good supplier as most prices I can find are around $60/Mtr
Edited by murrayis
  • 1 month later...
Ok a little bit of an update, Finished setting up the Haltech e11v2 and installed finally the Oil Catch Can setup.
Tried to turn it over today on what Haltech said should get it started as a Base Map not expecting it to fire and it didn't few nice Backfires and I decided to leave it at that
If anyone has a Map for a Haltech e11v2 for a rb25 with 750cc injectors I would be very grateful if I could get a copy to see if I can get the car running before I book the dyno and the tuner.
Anyway here is a quick Pic of the engine bay as it stands now.
Wheezy,
You are correct with a BMI 80mm Throttle Body.
Does anyone know what the firing angles for a rb20det are? I have them when I used a wasted spark setup but now I have the haltech I am not sure what the firing degress are.
Cheers
Cameron
Edited by murrayis
Wheezy,
Cheers
Cameron
120deg for an inline 6 IIRC?
Thats what I was thinking, I'll double check this with Haltech tomorrow just want to make sure as it seems when cranking to be popping weird as if the timing was all wrong.
Also need to get the type of CAS and if its on the Rising or Falling edge etc, I miss my Adaptronic where you could jsut tell it the engine and away it went lol
Cheers
Cameron
How do you find the KU plenum for response against the factory intake manifold? How is your top end also. I ask because I have one and have not spoken to anyone else who uses one on a 20. I just wanted to compare thoughts. Obviously the 2.4L will be a bit different, but close enough I guess :)
Wheezy,
Not having it fully tuned yet, results were pretty much as we expected its fairly responsive and flows plenty in the top end however I did port the manifold out to match the head and I also have 270 degree Cams.
Cheers
Cameron
Wheezy,
Cheers
Cameron
Interesting resultes, similarly; with my stock engine, I found it responded the same as a factory manifold but up top over 7,000rpm it keeps making power whilst an other RB20 I have seen with the same turbo drops off.
Cant wait to get some cams in it though.
Good luck tuning it! :thumbsup:
I Hate Tuners.... I spent 20 minutes yesterday trying to get it started, He sat in it turned the key and it fired up instantly!!!
And Yes the timing belt is a little too tight, Will have to back it off a tad.
Thanks again bubba for the Map.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
