Hey Guys,
I just came home from work and looked in the mailbox to find a letter from Sau....
I had totally forgotten about this so it came as a nice surprise after a hard day at work.
Anyway i would like to congratulate the guys who came up with this great idea, as now i sit infront of the laptop drinking a few Asahi (thailand brew tho) but still very good - which this great present has enabled me to open :)
If i could have 1 little whinge, i wish it had the whole S K Y L I N E word engraved on it but still..
ps. i'm a little drunck :ninja:
Thanks Guys!
https://www.sau.com.au/forums/topic/166721-sau-vic-keyringbottle-opener/
drinking a few Asahi (thailand brew tho) but still very good - which this great present has enabled me to open :rolleyes:
cough!... its japanese!
enjoy... i want one.
Edited by jake33
Hahahah - im glad you guys are enjoying them.
They are a gift to every member who renews their membership with SAU-Vic this year.
So in saying that - if your postal address has changed, it might be worth a PM to Kaz180 when you renew just to ensure we have your contact details correct.
:P
the aussie stuff is still brewed in Thailand (under Jap supervision)
Please don't get me started me on Asahi!!!
Australia only gets the Thai brewed stuff, which i chalk and cheese compaired to the JDM stuff. Recently i had some UK brewed Asahi, and it did taste a little better than the Thai stuff, but still not a patch on the REAL JDM Asahi. I have a few contacts for true JDM Asahi and 500ml cans of Sapporo in Melb.... but they are mine!!!! >_< [evil laugh]
I renuwed.... and i'm still waiting for a new card/sticker.... last time i trust a secretary with hairy legs :P:angry:
OMG I hope you're talking about Adz and not me, Age.. or there's going to be trouble ;)
We've had this discussion about Asahi before.. hey I'll swap you a case of the good Asahi (I'll pay for it!).. for your new card & keyring? heheh
Yep they are pretty snazzy :laugh:
I don't see why you guys can't just renew early!
Flysly: yep by end of Dec :)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
