Why would you skimp on something as important as engine oil?
x2
fully synthetic please
nulon hi-tech fast flowing has been going pretty well in mine but its not a true fully synthetic (only class 3, barely fully syn)
will be changing to Gulf Western S6000 Sougi next week, its hard to find but its as good as Motul 300v Chrono apparently but only $60-70 for 5 litres
and its nothing like the cheapo $12/bottle stuff supercheap sell either
worth looking for really
ive posted mods a few pages back,
got pod, fmic, boosted slightly more then stock, dump off the turbo, gutted cat and hks exhaust, thats about it.
i dont drive her too too hard but i still give her a push here and there....
Nice one. Pretty surprising you haven't got it retuned or anything. I just filled up today. 410km and 54L (13.1L/100km). Not brilliant.. I really want to get a wideband AFR meter and see if I can lean it out a bit more for normal driving. Hardly gunned it at all during the last tank.
I know I know what you mean. I have 3 cars and the other 2 uses Royal Purple which is not cheap. Although I use cheaper mineral oil for the Stag, I change it more often. Still that's no excuse! :blink:
Well now that one car is going, I thought I'd use a better oil on the Stag so hence the change.
my S2 gets about 320k's per tank, maybe alittle more if i am highway driving. main reason is that i have a gtr-s, front mount, exhaust,stock boost, stock maps (nistune fitted).
once i get the board tuned i'll find the economy will go up dramactley.
Thats pretty low for a series 2, especially with those mods... Hope the nistune helps dramitcally
...I also would like to say, i really hope to see under 10l per 100k after my nistune install, hi-flow panel filter and turbo back exhuast....
How has fuel economy gone since the nistune? I have very similar mods and am tempted if it's going to reduce my fuel bill dramatically.
Edited by webng
626kms 78.8L (not impressive, but it was fun :( )
As an aside, I would not recommend running so low on fuel in an M35, I accelerated moderately up a minor incline, only to have the engine drop out on me for a split second due to a lack of fuel picked up by the pump lol.
  • 5 months later...
G'day,
Just picked up a std S2 RS4V and drove it back from sydney to melbourne.
From Goulburn Caltex to Caltex Avenel 99% highway driving at 110kmph we used near on exactly 60lts of 95RON for 557km (odo actualy read 570kms due to smaller than std tyres fitted).
However a drive (correct tyre sizes) around town and highway, pretty much a 50/50 split saw a drop in 100kms of economy ie 470kms for again pretty much 60ltrs of 95Ron Caltex.
Deduce from that that maybe a drive 100% round town means 370km per 60ltrs - "Crikey"!
And also light comes on at close to 60lts used - Are these things 65lt or 68lt tanks?
Thought I'd add my readings.
"Safe Boating",
Mike.
675 km's for 75 L y'day
roof rack, windows down, air con on, no pussy footing
gonna fit a fuelstar fuel catalyst soon too so will get back to you on that when I do
The available evidence would seem to indicate these are a con. Did you fit one and has there been a long term difference in consumption?
G'day,
"Safe Boating",
Mike.
grab yourself a new oxygen sensor and it should help out a bit, the sensors only have a limited lifespan and rarely get replaced in japland
i also run 95 in my stagea due to the exorbitant price of 98 in tas but it does lack a bit of power compared with 98 and i get slightly less fuel consumption with it too (the ecu will run more timing on 98 = better fuel economy)
no one makes an aftermarket o2 sensor for the s2 stageas (rb25 neo same as r34 gtt) so its either stock nissan one for about $250 or get one for a s1, r33 gts-25t, n15 sss pulsar and cut and re-crimp the wiring using your old plug
Pipster11 thanks for the comments.
I have read all the comments on fuel economy in this and other threads, "helpfull info - thanks everyone" (O2 sensor change duly noted).
The 570kms that I got, all be it highway run, seems to be quite good when compared - so I am more than happy with it. Had a bit of weight (4 x 19x8.5 with tyres) in the back aswell.
It's daily route will be 85% highway 15% town - hoping for at least 500ks a tank normal driving.
Cheers.
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
