As alot of people know the R33 has a very annoying axle tramp off the line.I dont know if this has been covered before but how can i get rid of it?
Im getting a set of pineapples for the rear but surely this alone wont stop it.
Now this is close to my heart.I have asked this question a few times myself.I installed pinapples and this reduced it somewhat but was still almost the same.Replaced the springs and shocks with kings springs and much improved shocks but only a little better again.Still,a worth while improvement.Replaced the wheels with light weight ones and you guessed it,only a slight improvement.After spending what was now a few thousand dollars I was stopping the rear end from trying to rip itself out of the bushes so then replaced the bushes with whiteline ones and this was yet another step in the right direction.
So I went to some people in the hot rodding scene and found that they had great success with urathane diff mounting.This means the subframe as well.You see a solid diff is difficult to control due to it`s weight but an IRS has far more mounting points,each one of which has the potential to move under accelleration causing the tyres to bite then skip repeat,repeat etc. etc......My next step is to replace the subframe bushes with urathane and the diff mounts as well.I have a strong feeling this will eliminate axle tramp all together.I know CUBES did this so would be interested to hear if it affected his 32.HEY CUBES,you reading this?
Thanks Gary atleast now i know what to tackle.Looks like ill be buying alot of urathane lol
Sydney kid, One day u have to come help me fix my axle tramp. Ive been trying for years to get rid of it to no avail. Been to suspension shops, tried different tyres, installed pineapples, and was about to change shocks and springs.
It just never wants to go away
I replaced my subframe bushes and found axle tramp has reduced greatly and torque steer feeling through second gear has completely dissapeared; on the dyno the whole sub frame was moving around a hell of a lot.
Most of the time it doesn't axle tramp but when it does its now a light little thud not like the old BANG BANG BANG your going to break an axle bang. :S
The subframe bushes Improved axle tramp 10 fold. I am still on stock shocks and springs as almost everything aftermarket is lowered which I don't want. Minimum legal height here in SA is 360mm mine sits ~365mm with stock bits.
I'm considering a set of teins as they have the screw type heigh adjustment that can be adjusted to stock/legal height.
What about the traction rods? I had a look at mine and they do feel a 'tad' loose, possibly the bush is stuffed which causes tramp. Reading up on them 'apparently' traction rods in good nick prevent tramp?
Nisskid,
A mate of mine runs the bilsteins and they are still too low. Unfortunately he has recently been defected because it was too low. From memory the front was too low 10mm and rear 5mm.
If you look and ask everyone who's been defected and what for its almost always.. 1. too low 2. tint 3. too loud
I've almost been done for tint so I removed it on the spot. Height, even though it looks stock a tape measure was put to it.
Its simply not worth the hassle.
Are yours on the highest setting? Are you able to measure the front and rear heights?
Nisskid,
rear sits on just 340, the fronts sit about 350, that is the reccomended setting but not the highest, i beleive there are 2-3 grooves above this one which are a bit under 10mm apart. i have the extra grooves but most are for lowering it further, if i put mine on the highest setting i reckon it would sit a bit above standard height which is with lowered springs. id talk to SK about it but pretty sure the bilsteins with extra grooves would be more than enough to keep standard height.
Where the rear end of the car, on a launch will basically "bounce" and is then hard to get the power down and at the drags, will ruin your pass basically!
Is the bilstein setup that SydneyKid sells good/stiff enough to prevent this?
Do good grippy tires help prevent it too?
To be honest - I myself havent had much axel tramp issues in this car. My old VT LS1 commodore had major issues - was a biatch to drive :laugh:
Since I've had the syd kid group buy springs/shocks in my car Ive only done one night at WSID drags and had a little bit, but I think that was due to my "hard launch" (1 launch out of 5) - done a few motokharna's where you need to get a good launch for a good time - no a/t at all
Tyres - I guess? but Im not 100% sure - I used semis for the first time last weekend at DECA for a motokharna and had no issues
So in my case - 98% of the time - I havent had it!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
