I will chime in here.
I used Intima SR for a track day. and they sucked a big proverbial dick. I literally crumbled them on the track.
QFM a1rm did 3 track days in one set of pads and they stopped my boat much quicker.
So for me the intima pads are "garbage"
The ss would be on par with the hpx, which I now also have and they drive absolutely great for normal street duties.
That is extremely interesting, I myself went from A1RM to Intima SR and found them great.. 2x of my mates with EVOs also went from A1RM to Intima SR and found them better.
Another track wh0re I go with on his 180SX went fro A1RM to Intima SR and found them great too albeit he runs R33 Brembos on his 180SX.
You may have had a bad batch or so.
  • 3 weeks later...
Help me pick some pads :)
mostly reading about qfm hpx, a1rm and intima ss and sr's. These are the main ones talked about in this thread and google. Unless you guys have or know of something better for me?
the hpx are 500* and the ss are 400* Both don't chew rotors, but are far from the 700* of a1rm and sr's
I'm looking for a semi crossover pad. Something that will perform well on the street 60-80k roads with plenty of braking up and down hills for 30-60 minutes at a time, but wont chew rotors in traffic.
The rear pads will have to be used for both track and street. fronts will be changed to SRT's for the track thanks to Luke. Will be on t3 rotors f+r
All good! Joe just hooked me up with some rear remsa pads, seem to be perfect for what i want. 650* with lower rotor wear and a lower cold starting degree.
Remsa is an awesome pad from completely cold... but are dusty af.
  • Like 1
Correcto, I had remsa all round once apon a time. Not a bad pad at all, except for the dust. Dusted more than the vdub.
Honestly if you want a 50/50 pad, then you gotta choose between a1rm or SR's. Or drive with dedicated street and swap over to track pads.
  • Like 1
thats the plan ;) needed something decent for the street but not as agressive as track pads.
Will be changing the front to srt pads for the track
edit: update. Just spoke to GSL and he mentioned not to change pads without skimming rotors.
I had Intima SS on my R34 GTT (IN1170M-SS and IN1220M-SS) and melted them on a hilly drive near Black Spur, no good.
Upgraded to Remsa (0348.02 and 0365.02) and they are going great on the street and around Sandown with DBA T3's.
Hard to beat for value, you just have to be prepared to put up with the dust, they are very dusty.
  • Like 1
How about pads for D2/KSport/Attakd kits?
Are these options even available? I know I want to upgrade something before I attempt to stop my barge on a race track, and the pads that came with the kit (green ones) I can induce brake fade on the street in about four corners and have had brake pad splatter all over the place.
Clearly not ideal lol.
Been Recommended Pagid RS29's, but they are in the region of $700 for a set.
What else is comparable?
  • Like 1
I used to swap between QFM HPX (street) and A1RM (track) and didn't have any issues. Changed to Winmax W5 for track use and that resulted in some massive brake shudder because the HPX pad would just layer on top of the Winmax material. Once I had the rotors skimmed it was all good again but I won't be swapping pads again without skimming.
As far as I am aware, track pads dont put much "layer" on the disk due to their aggressive characteristics. So technically when you put track pads on after a different pad it should clean the surface for you.
Maybe you over heated the rotor
Other way around, the issue was with the street pad layering on top of the track material. Swap back to track pads and do some hard braking and it mostly cleaned it up then swap back to street pads and not long after I would get shudder again.
Didn't have the same problem with HPX and A1RM I guess because they're a "similar" compound.
Now running Ferodo DS2500 pads full time.
And if you utilised your track pads as "rotor cleaners" then you wouldnt have the transition issue.
Whilst keeping the track pads cold, everytime you brake it will clean the rotor bit by bit. Continue to do this at street driving level, dont enter bed brake in mode as that will heat up the pads too much and start transferring onto the rotor.
This way you could transition brake pads.
Has anyone heard of RoadHouse brake pads before, or better yet has anyone actually used them?
I decided i'd try some Remsa pads so ordered some through a reputable trader. I was very disapointed to see these RoadHouse pads had been delivered instead.
They came with a letter stating; "In Europe, Remsa pads are sold under the RoadHouse brand... In Australia RoadHouse pads are supplied if there is no stock of the Remsa pad at the time."
I can't find much about the RoadHouse pads on the interwebs, so hoping someone has experience with them.
Considering sending these back and ordering some Intima / QFM pads from one of the forum sponsers instead.
Remsa are standard pads. They are made in Spain (also know as Roadhouse in various markets) and are ECR90 rated, which means +/- OEM performance. of course I am prepared to be called on this information by GaRkson, as they know best. Granted my knowledge of the product only comes from selling the **** for 3 years while I worked for Autostop/ASL and the various training days we had with Remsa.
They are Remsas. Isn't that what you wanted?
Part numbers?
My Remsas are 0348.02 and 0365.02, from GSL RallySport. They are rated 650 degrees C from memory so definitely not OEM/standard style pads, also much better than the Intima SS that I had prior. Very dusty though.
Edited by V28VX37
Well if RoadHouse = Remsa, it looks like I got what I paid for so gotta be happy with that, still would of been nice to be notified prior to purchasing that they were out of stock of the Remsas and Brand replacement will occur.
I'll be putting these in anyway but would love to hear if someone has used RoadHouse branded brakes in the skyline.
Part numbers?
Part numbers: 0234802 and 0236502.
The letter from the supplier also says "The RoadHouse part numbers are exactly the same, save for the '2' at the beginning"
Going by all the reveiws on here i see that they are dusty but also a street pad rated to 650 C, so a little higher than Bendix Ultimates / Intima SS / etc.
  • Like 1
Yep sounds like a match, good to know!
From what I've read they're supposed to sit somewhere between QFM HPX and A1RM. I wanted something street friendly that is still ok on the track, without chewing up the rotors. Also A1RM's apparently can be squealy, the Remsas are quiet, just really dusty.
Here's the description:
http://gslrallysport.com/au/348-02-remsa-brake-pads.html
http://gslrallysport.com/au/365-02-remsa-brake-pads.html
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
