I got sent SR instead of SS pads for the front of my Subaru, they bite very well (sometimes a bit too hard when they warm up, for smooth easy braking) and the brakes are strong. Too much for a daily driver though IMO. Not surprised they work well on the track. The A1RMs on my GT-R however, are most likely glazed over and are rubbish now (after a couple of track days/years).
I don't know why everyone raves about QFMs.. I once thought they were good too.. till I nearly DIED!
Anyhow, if anyone needs Intima Pads SS/SR/Type-D hit me up - will take care of SAU boys and their friends!
  • Like 1
What do you have to fit the 8 pot ATTKD calipers for track only use?
I'll check with the manufacturer, because I don't have a listing for those :)
Do you know what other caliper uses the same pads (for reference)?
4 hours ago, Duncan said:
They take pads for the AP racing 6 spot calipers, common motorsport size with lots of options but I don't have a part#
awesome thanks Duncan!
I'll find drawings tomorrow for them and see if they're a goer!
Sorry for the late reply - as per Duncan's reply they use AP Racing pads. I don't have any part numbers either. Don't need pads just yet but no doubt we will later this year.
I put Pagid pads from RaceBrakes in mine but sorry don't have the numbers.
Got details back from the supplier, unfortunately the Australian stock is just the standard Intima SR, which are 0 to 700 degrees...
but..... if there's enough demand, we can ask them to order them in the Type-D range, which are 250 ~ 850 degrees - however they're made to order.
Ok peeps, I've been running Remsa (sometimes labelled Roadhouse) pads for a while now, generally ok except very very dusty. They're rated 650C.
Thing is, I kinda killed them at Sandown last Sunday, fully glazed over after 3 sessions ( http://www.sau.com.au/forums/topic/463353-post-track-day-qs-rotor-wear-gearbox-oil-ps-pump-manifold-nuts/?do=findComment&comment=7763092 )
I'm now thinking of upgrading to something like Intima SR or Type D ( as per http://www.trak-life.com/intima-brake-pads-review-sr-type-d/ ) – not entirely convinced though as I had a bad experience with Intima SS back in the day; they completely melted on a mountain run.
Another option is Brakes Direct's Forza line: http://brakesdirect.com.au/forza - maybe FP3, FR4 or FR5.
I'm still after something that is somewhat streetable i.e. with a low-ish C rating at the bottom of the temp range. Any recommendations?
EDIT: Also anyone know who might be able to supply cooling duct brackets to suit the R34 front hubs, to channel air into the inside centre of the disc to feed the veins? The OEM heat shields have been cut off.
Intima SS pads are 0 to 400 degrees though, so yeah not really a good pad to use on a Mountain run..
Intima SR pads are 0 to 700 degrees.. so more suited for your street sprints, mountains, track work etc.
Intima Type-D pads are 250 to 850 degrees... a little shit on the road when cold, but they sure pull up once there's heat.
Happy to help you guys out, will throw in free shipping if you order 2x sets of pads and bank deposit instead of GheyPal.
  • Like 1
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
