i have my car on the front lawn and i have lived there for 18yr s without problem no the best hood to live in
anyways
i walk out to go n pick up some chinese and here are two lil c*#ts with the legs hanging out of the window of my car i looked thought wtf
and went right off my nut grabbed one, the other got away i woke up the whole neighborhood he was crying i was yelling i sat on him in the end and im 100kg he would have weighed 40kg is that
any ways cops came around they knew who they were the lil fella dobbed in his mate they arrested them both
the stole my steering wheel it had a d1 quick realese on it didnt get time to steal the sunning sterio ebc or anytthing else
i cant move the car now shits me
the olny good part of this is i now have 2 good mountin bikes in my back yard
i cant belive the nerve of kids that old 13 ffs it was like 9.50pm
the kid is that dumb he told me where he lives and to drop the bike around haha pfft like f**k
not happy i think they have scratched the car
https://www.sau.com.au/forums/topic/170367-13yr-old-break-into-my-skyline/
  • Replies 94
nice work on catching the dirty little thieves. I hope you make the fkers pay for your car. as for the mountain bikes? what mountain bikes? I don't remember any mountain bikes in your backyard...
fark! i would have held him up in the air by the lil pricks throat and demand he get your steering wheel back from his friend. considering the cops know, and know where they live you will get it back right?
oh yeah, howd they get in??
haa.. thats a piss funny story.. I mean . its never fun finding your car being defiled by little snots like that. but you did give me a good laugh thinking of you sitting on one of the kids.
sheesh! seems kids now adays are SO HELL BENT on growing up faster than they should!
what ever happened to kids being kids you know?
now kids seem to want to get laid at 10 and graduate college at 15 or something !
not hard to get into a car. especially a skyline. you just pull the window out far enough to get something in to open the door. they need a deadlock on them.
as for the steering wheel. kinda serves you right for having a steering wheel that is a theives best friend. even though they won't be able to do much with it, it makes life hard for you. especialy if you leave the car somewhere exposed. you either have to get it towed, or leave the car where it is which gives them time to have another go. i'd make up a thin wire cable loop (kind of like what computer shops/phone shops use) to make it so the steering wheel can only be removed and put up on the dash, but can't be taken out of the car. sure they could cut it, but it will stop the smash and grab types.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
