  • Replies 233
Hey guys,
Payment posts updated.
The following people have to tell me 100% ASAP whether they are still keen or not so I can square this group buy off.
Haysey
SNISMO
Govich
RSTME
teazn_r33
russo1
r33_nikolas
Skyhy
Taxi33
frx026
WogsRus
OI_Mate
It's not a problem if you want to pull out, you just need to let me know.
Okay, some update info.
Originally I understood the manufacturer had the R34 design, but not the R33 or R32, so I sent the manu. a rubber pipe of each design.
Turns out, he has the R33 pipe, but not the R32 or R34.
SO, the R33 pipes are pretty much on order, just waiting on payment logistics for OS. I have a couple of spares ordered for the just in cases and the 50/50 people who haven't gotten back to me yet. I'm taking a punt, but I think it will be okay.
The R32 pipe is being prototyped, but I DO NEED an R34 pipe.
Does anybody know of any around? Please let me know.
"What does it all mean Basil?"
Well, if you have an R33 or Series I Stag, you are sweet. Shouldn't be too far off.
If you own an R32 or R34, you may have to wait a couple of weeks more, as I need to get an R34 pipe to the manufacturer.
I apologise for the delay, but understand that I'm going hard at this one for you all.
I'll be buying all the Express Post bags soon also and will be writing up a few a night to make sure that when I get the pipes, you will get them very soon after.
Cheers Guys
BASS OUT
Edited by Bass Junky
Good on ya pete. These seem like a good thing. It'll be interesting to see if they make any noticeable difference. For me, the most important thing is that it is straigth bolt on.
Do you reckon we'll get it before the 30th july? that's when my holidays finish. it'd be good if we could get it before then :)
Manwhore,
I sure hope so.
Did you know that there are some WRX tuners who are charging up to $680 for similar pipes to this?
Granted they have some aluminium bits sticking out of them, but I can do them for about $170-$180 max.
So, yeah, I reckon commercially these Skyline ones are probably worth about $300 odd.
Lucky Us!!!
yeah, definitely, these are worth a decent amount. good on ya for organising this. Everytime I do a turbo install, and I look at the stock pipe, I hate it.
We're getting em for a good price. This is affordable.
Okay ppls.
This will be the last reminder for the following peolpe
RSTME
russo1
r33_nikolas
SoFly
OI_Mate
Haysey
You have until Monday to confirm, or you cannot participate in this group buy.
I'LL EXTEND UNTIL MONDAY ONLY
Everyone else, I've got all details. Almost ready for action.
BASS OUT
Cheers Mr Bass - Yep I'll take a blue one for my series 1 Stagea. Let me Know the total inc. international shipping to the UK and I'll paypal it too you the next day. Ta very much!
John
GROUP BUY CLOSED
PARTS ON ORDER
If anyone who isn't included in this group buy wants one, please let me know there will be another group buy after this one by the look of things.
BASS OUT
I am in for the next group buy for both the radiator pipes and the turbo pipe.
Send me a PM when you are ready to do it.
Cheers
Shaun
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
