  • Replies 233
The following people are the first lucky contestants to have their cool blue silicone inlet pipes shipped!
SydneyKid. Gary always gets priority as he's an SAU god.
R33Driftr
Beastien
Skyhy
Darrinspencer
Chuckie
Keep an eye out for an Australia Post 3kg airbag.
I reckon you'll all get them either Monday or Tuesday depending on location.
BASS OUT
R33Driftr
Beastien
Skyhy
Darrinspencer
Chuckie
BASS OUT
thank`s BASS ,chuckie
Bass could you please update the first post with a PAID next to my name.
I don't want anyone to think i'm all talk :P
same with me dude
im a blue and paid fo shu
Darren I'm looking forward to your thoughts.
She should fit like a charm.
Black ones still on the way. Should leave sometime this week from my supplier. Not sure that I'll get them this week though.
Sorry GTShortie.
But if I do, then yeah, I'll shoot it up straight away.
Hi Jase.
If you (or anyone else) is using their standard rubber pipe, this will replace it.
It's 100% identical in shape to the standard pipe.
Cheers
Pete
