http://www.j-spec.com.au/list/10753
and my fav oldschool wagon that's worth big bucks to the right people
http://www.j-spec.com.au/list/2242
I've got pics of a 180sx wagon somewhere... and build up pics of the R33 Option wagon back when it was blue (they used a Nissan Exa back to make up the wagon bit). There's also an FD RX7 wagon made by RE Amimaya.
  • Replies 191
another rotary wagon:
http://www.j-spec.com.au/list/6404
bluebird turbo wagon:
http://www.j-spec.com.au/list/7946
Toyota Mark II JZX81 wagon
and while its not a wagon... based on the legendary Kingswood (which was a popular wagon :D)... a Mazda Roadpacer
doesn't the L series have a MASSIVE hump at the front of the rocker cover for the cam wheel?
well, the L20 in my last 2 bluebirds did :D
Correct, the lump kinda looks like a single-cam old-school SR, except the spark plugs go in the side of the head, not the top - the cam would be in the way... :P
well, the L20 in my last 2 bluebirds did :P
the lump on the L serise isnt THAT big :D;)
could be a early CA.. but from memory the carby CA has dual spark plug on each cyl
2008 Mercedes-Benz C63 AMG Estate?
Edited by Brycey
  • 3 weeks later...
  • 1 month later...
I have seen these in the flesh at Ernie's Skyline Imports in Brisbane. They are called 'COO' and they look as good as the photos.
They are brand new and awaiting compliance. I think they would make an awesome runabout for the wife and kids without looking like a complete idiot driving a Smart Car.
  • 4 weeks later...
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
