so nick...i heard u got it retuned, or is this just a rumour?
o did you now lol yep it did
soooooooooooooooo after being totally disgusted with my past tune in more ways than one i took the car to a professional JEM (Adam) an not a self proclaimed prodigy as i did be for.
after taking 20 deg of timing out of the tune and fixing all the holes and flat spots and much much more errors the car is perfect.
things jem did for me
Tune the car in the way it was supposed to be done from the beginning.
engine protection set up with oil press,inlet temp and wide band sensor
wire meth to map sensor
wire press sensor
install wide band
replace temp sensor
new plugs
road tune after dyno with me driving
and a total respect from beginning to end of the customer and all done in 2 days not 16 days
all this for a $400 more than my worst experience ever who did F/A
turbo spools much earlier boost is much smoother it makes 200 odd nm of torque more a/f ratio is 11.8 be for it was 12.8
end result it a well tuned 356kwatw with 913 nm or 672.7 ftlb @ 8200 rpm
take me for a spin take me for a spin lol :action-smiley-069::action-smiley-069::action-smiley-069::action-smiley-069:
me me me me
sounds good to me will find some time with marko and who ever won't one day
Edited by WARLORD
  • Replies 539
Wow, sucks to hear the old tune was THAT bad... Flags raised for me from things you mentioned though, so really glad you took it to JEM who yet again convince me that they are a class act, and glad it happened before damage wad done! Congratulations on a good result :-)
thanks, i was told that im lucky the engine is still alive,or even running with the settings i compared i am totally shocked,
i should really be given back my money for all the bullshit i went through
Edited by WARLORD
So did Adam do a back to back run with the old tune? Would have been good to see an overlay of both
IMO if JEM is capable of tuning the ATCC GIO GTR, they know what they are doing...this is when JEM gained my respect
Great to see u are finally happy after a very long and rough run nick
  • 2 years later...
you twisted my arm things that have been changed or being changed.
valve springs,rear arms ,fuel setup: rail ,injectors, fuel pump,e85 solenoid,diff gears to 3.9, gtx3582r ,sinco manifold ,wastgate ,seats,and more shit i can't remember
should be ready soon i hope a fair bit of fabricating to do but that's ok .....i hope.
last year s/m 1000
https://www.youtube.com/watch?v=bvEaDXwRy8g
Edited by WARLORD
  • Like 3
That Sinco manifold is a true work of art and it's not only me that thinks this....I've never seen such good fabrication!
Hey Nick, what is the puff of smoke towards the end of that run from rear cabin view? Is that when u hit the Flux Capacitor injection :)
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
