Can anyone provide me with the latency times for nismo 555cc RB25DET injectors please?
I reckon it would be sweet if there was a database for the most common injectors latencies and whatnot...
Double that request for Nismo 555cc injectors latencies.
I can't find that data anywhere.
come on.... someone must have latencies for yellow Nismo 555cc injectors.
Must be the one of the most common upgrades.
If anyone has them please have look in your PFC hand controller and see latency your tuner has used.
There are three people here waiting for this and probably more that will benefit from this information.
It will at least let us drive our cars down to the tuning shop with some peace of mind that the fueling is not excessively lean.
Once my car is tuned I will post up the latencies my tuner has used.
have you not tried googling? nismo 550cc lag time nismo 550cc latency etc. keep going till you find it, the truth is out there. That's what I've done every time I needed to know and injector lag time and it's never failed me.
Yep, tried the google. Nismo 555cc get a few more hits than 550cc but still no success.
Heaps of forum discussion, no solid data.
- Japanese instructions do not mention anything.
- No data on Nismo website.
- PaulR33 FAQ does'nt list 550cc Nismo injectors unfortunately.
(http://paulr33.skylinesaustralia.com/docs/powerfc-faq/powerfc-faq.htm)
If anyone is running yellow Nismo 550cc injectors the sharing of their PFC latency setting in this thread would be appreciated.
Incorrect latency settings can be fixed by compensating the fuel map but that is a less than satisfactory outcome to my mind.
Only data I can find is 0.710ms. However, I would personally prefer a more reputable source than this random thread. :(
http://forums.freshalloy.com/showthread.php?p=1452662
HAHA sorry i forgot :D
nismo 550cc 0.71 :P
Std lag times to calculate differrence; (for some reason i lost my second decimal place :( i will fix it asap
RB26DETT
440cc
0.77ms
RB25DET NEO
380cc
0.6ms
RB25DET NEO
380cc
0.7ms
RB20DET
260cc
0.7ms
SR20DET (s15)
480cc
0.5ms
SR20DET (s13)
370cc
0.7ms
SR20DET (s14)
370cc
0.7ms
CA18DET
370cc
0.6ms
2JZ-GTE
440cc
0.9ms
3S-GTE
540cc
0.5ms
4G63 (1-4)
510cc
0.8ms
4G63 (5-8)
560cc
0.8ms
13B-REW
prim 550cc
0.8ms
sec 850cc
0.7ms
EJ207 Sti
520cc
0.7ms
BLITZ PERFORMANCE INJECTORS
UNIVERSAL
1000
1.00
RB26 / CA
700
0.65
RB26 / CA
660
0.55
RB26 / CA
534
0.85
1JZVVTI
525
0.99
1JZ / 2JZ
540
0.56
SR / RB25
550
0.85
SR / RB26
850
0.85
2JZ
850
0.85
Interesting thread. My experiences with nismo 550's on a sr20 was that they lost the ability to deliver fuel properly below 1.45-1.55ms. That was firing the injectors sequentially on low impedance injector drivers.
So I am guessing the 0.71ms latency means time for the injector to change from closed to completely open... and not back to closed again.
I've read that some sard regulators are stable down to 1.1ms with stable fuel delivery, so the latency has got to be close on 0.45-0.5.
Cheers,
Ian
WTF... do nismo even make 550? isnt it 555cc? anyway.. im after the EXACT Latency times For Nismo RB26DEtt 555cc injectors. to re-configure the Power Fc..
Thanks Guys,
If anyone has 555cc injectors on the power fc and run them on an RB26DETT please goto your car and check the Latency time set into your hand cntroller hanks guys.,
  • 7 months later...
Hi Guys
Sorry to bring up an old thread, but i need a bit of help.
I will be installing my nismo 555cc injectors and setting up my power fc for the injectors in the next couple of weeks (running a HKS 3037 Pro S and all the supporting mods) before i book it in for a tune, i have worked out the injector correction and injector latency correction numbers that i need to change in the PFC, can somone please comfirm for me that these are 100% correct? :D
"INJECTOR CORRECTION"
- Formula = stock 370cc divided by nismo 555cc = 0.66cc x 100 = 66%.
So i would go into the power fc and change the INJ correction to 66%, correct?
"INJECTOR LATENCY CORRECTION"
From what i have found the latency for the nismo's is 0.71msec and stock is 0.52msec
- Formula = nismo 0.71msec minus stock 0.52msec = 0.19msec
So i would change the INJ Latency numbers for each injector to 0.19msec, correct?
Hopefully this can help people in the future that are looking for the correction numbers :).
By the way, someone should sticky this thread!!
Cheers
Edited by nizmo_freek
    • Yeah pretty impressive hey, good to see quality products not over-shooting their prices. That's what drew me to buy the hypergear turbo, just a shame I've never got the chance to see it in action
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
