hey guys just saw on ns.com:
(im quoting)
"Called Jo from AIR management today and she advises that with the recent court decision in Bob Janes favour that they can now re-open the facility more widely now.
This means street drags should be able to resume in about Oct/Nov this year.
IF SA provides enough interest and support to the facility it will only get bigger and better and then they will start to run $ competitions, and after time the funny cars, doorslammers etc. will be able to return.
Jo would like us to publicise this so if you are on other forums please post up, lets not lose it again ffs!"
https://www.sau.com.au/forums/topic/173774-air-drags-re-opening/
  • Replies 43
I was speaking to the guys in Outlaw speed shop the other day about this. They had been told the same thing, that street meets should be back come october. Here's hoping it happens because I will DEFINATELY be out there next summer if thats the case.
I seriously doubt competition would be back anytime soon without the upgrade. 7+ years without competition cars will easily extend to 10 I reckon, as even Calder hasn't had competition meets for ages due to Bob f**king ANDRA around.
But in the mean time I'll be happy just to get some 1/4 times for the '33 at street meets. ;)
yeah I heard this too.
But I have also heard from a couple of sources that the track is in pretty poor condition and needs to be resurfaced before drags can be held.
If Bill and Co. had won the case they were going to put in timing boards - I wonder if BJ will bring us into the 21st century and finally install some for us? Makes watching drags 1,000,000 times more enjoyable when you can actually see what times all the cars are doing.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
