nice looking cage mate! i bet you cant wait to get racing it! ;)
seeya soon russ
will try get the car ready have atest at the sat arvo sprints at QR on the 15th... body got painted tonight , hopefully some photo's tomorrow
WOOOTNESS :blink::O
Some pics of the cage in my R33GTR the car is coming along nicely. Suspension and Brakes are done just waiting on some bits at the machine shop to make a start on the engine then the real fun can begin. :D
hey dazmo,
where did u get this done and roughly how much?
thanks bud
hey dazmo,
thanks bud
He mate I had it done at third dimension race fabriction on the gold coast 0422412593 Ben Van de linde is the guys name. I stripped the car and dropped it of to him he had the car for around 1 - 1.5 weeks and total cost was $2800 he did a really good job got all the bars really close to the a pillars and roof and all the welds are really neat. I am extremely happy with his work and would highly reccomend him to anyone. The cage is made from CDS and is fully cams approved and will be RTA approved once i get the final inspection done and the mod plate signed off.
hi gents
car is painted & hypertune six throttle body intake manifold has turned up! awsome!
cheers russ
Looking awesome!
Shoot me a PM when ur running in QLD would love to come see it, ill try chase u down in the 35 ;)
Looking awesome!
Shoot me a PM when ur running in QLD would love to come see it, ill try chase u down in the 35 :D
Make that 2 Russell. I will be chasing after you in my other track/street car
I think I will need a few more ricer hondas to block u at the front though
hi gents
cheers russ
Hey mate, any chance you'll be at QR around the first or second week of september? my brothers wife is dew around then and i'll be up in brisbane for a week or so i'd love to come check it out.
maybe at QR on the 15th fingers crossed!
cheers russ
if your still free and in the country...come whoop all our asses in rd3 of the state championships! 29th and 30th september.
I would rather be beaten by another nissan then a stupid toyota.
Edited by r33_racer
we run the hoosier semi's and dunlop full slicks. Depends what we can get at the time.
Yeh johns car did a 54.3 on full slicks on the sprint track at the last top gear day. Reckons he still has more in it...i hope hes lieing.
worth while posting this question in this thread...
Ok - Is there any benefit for a rear half cage for a streeter/trackie?
I think Richard (BB) has one in his GTR, so I guess Im just after a wee bit of discussion on that area.
My 33 is bascially now, rarely driven on the road, Ive got a daily R31 so Id rather have the 33 well set for 'khana's and sprints but just wondering bout the rear haf cages
Thoughts?
Cheers,
Chris
Awesome, good to see you're back on the track. How was it switching over to meth, would you recommend it?
its definately more agressive on methanol and runs cooler but theres more maintainance involved
will find out more in october when we run it with 28 x 10 tyres and a bigger converter
Thoughts?
Cheers,
Chris
i've got that kansai cage in my gtr, two bars down near your legs to the front and the rest is just the rear cage section, you surely notice the car is more stiff and feels tight! tho there is also the whole kansai package on my car with all under bracing also..
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
