car should be at QR inthe morning tomorrow!! for a bit of a shakedown, testing dry sump and breather setup, cooling system etc.
Awesome, i'll be out for sprints in the arvo so i'll make sure i get there nice and early to see your runs :blink:
Giant, sorry I could not come to QR early enough to see your car. How did you go? Is there any chance that you could post some pics of the lexan windows? I think I need give my skyline the Jenny Craig diet :)
hey guys
for an update!
went out saturday morning to do a test. did about 15 laps maybe 18? ( in 3 sets)
intial test! result excellent!!!
dry sump test - perfect
cooling system, oil and coolant- perfect
doors and windows didnt flap around
cage result - really feel the chassis stiffness
testing at about 85 percent on re55 hards, mark did a 1.17:5 on the national which beats our previous best of 1.17:9
very promising on soft semi's at 100percent should put us into the 1.16 bracket wven there werent other mods.
next to test is
ohlins coilovers (due this week)
4 inch side pipe :laugh: (already made)
different injectors (ready to go)
soft compound rubber (due now)
will keep you posted and some more pics soon.
cheers russ
p.s we did have an oil leak (helps to put the dipstick in or plug the tube/hole!!)
i was there and saw the 32 go round...it is damn fast and its not even finished yet. The japs wont know what hit them.
While russ and mark had a good run, we blew a turbo the same morning :) Seems a perishing rubber line that supplies oil somewhere had bits building up in the turbo oil feed, blocked the hole and ceased the turbo.
P.S I love the doors russ, so light. Im telling ya mate, full slicks. Try a few runs on a set, you will wet yourself with the amount of traction you will get over the hard semis.
Latest pics of my rally car from this weekend...
7 fence posts at 130km/h
Damage report:
Bent right rear suspension, looks like just the lower rear suspension arm
The scratch (and small dent) on the rear guard
Missing fuel filler cap (somewhere in a padock)
Missing rear window (also spread across the paddock)
Squashed fuel tank - surprised it's not leaking actually
Bent wheel
Broken headlight
7 fence posts (One thrown 15m into the paddock where the glass and petrol cap are)
Bet you didn't lift off though?
Kept the foot in it the whole way, until it started heading for the bank, then I gave up and applied the brakes. Just needed more steering lock! Strong old things tho, once untangled I drove it out of the stage.
Damage report:
Bent wheel
Broken headlight
hehe!!
thats the shit right there!!
130 clicks hitting fence posts and the foot still buried!
love ya work!!
cheers russ
Hey screamin' - I found out last week the Dutton Rally is having a round in N.Z. next year. We are currently planning on getting over there for it. Hopefully we can see a few local based Skylines for the event as well.
BTW Russ - no round in QLD next year. So you guys will have to come to Vic (or N.Z.!)
ahh damn it!! means i dont get a cheaper round.
might have to come to vic to play!! :yucky:
They are stepping up the Dutton events next year Russ. Some of the stuff should be tops. :yucky:
Also - I've pretty much convinced Mossy to bring back the free entry for reigning champs so you should at least get free entry to NSW next year. :)
Good man!
Hey sounds good. Dutton is a tarmac rally similar to a Targa isn't it? We've only got a handfull of guys running Skylines in that spec here. Most guys with money run the GT3's.
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
