Roy, you know you're welcome to come and skid mine anytime up here! Sunday 21st of this month... get a flight, come drive Lakeside.
I beleive I can Savman. And Rex is super quick! I reckon I'll be right in the rain, but if it's dry, that thing has some serious pace! 380hp and about 1100kg will do that :)
Edited by Marlin
I have just the thing for your car to make that power. Internals are free, that is all i keep hearing from Tarmac rally guys :rofl:
yes troy, internals are only free if you're losing dumby. if you're winning almost nothing on your car will be not under protest...
BTW, is it just the pics or the wheel nut to wheel fitment a bit howsitgoing? could be worth getting some different nuts that fit the taper of the wheels holes a bit better. :)
car looks sweet as, and nice choice of seat... (yes I run the same :) )
Yes Troy, as I've discussed with you elsewhere about the cheating phenomenon, it's just not my style. I'd rather wax the Porshes in a true sh*tter :)
The wheel nuts are fine, it's just the picture, no interference there as all. I'm saving for a set of RAYS nuts though.... I couldn't even find any all the same colour! :)
The seats are the best ever... it came with them and I was stoked. Having used them for the last two Targas, spending six solid days in them, I know that are simply the most comfortable and supportive seat I've ever tried.
Thanks for your nice comments too :)
Thanks Chris :dry:
Very easy to do, just rivetted to the original.
I find it help in situations where for whatever reason you may get a long brake pedal, there's far less chance of going for a heel/toe and getting under the accel pedal.
I had that problem a couple times at wakie last weekend, braked too deep and my foot couldnt hit the gas properly while changing!
Thanks for that!
Cheers!
  • 1 month later...
MPC used to look after my car when I kept it in Melbourne. I saw a few cars there they look after that had flocked dashs. Maybe they're the flocking experts? I'll give the boys a bell and see where you can get a good flocking.
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
