It should easily slip into the 16's with good tires as it was on Sunday. Thats what I was aiming for come the afternoon sessions but its hard with only 3 laps too..
Still coming to grips with the major changes to suspension geometry, Its not as easy as we thought to get it right. We struggled through the last 4 or 5 test days making small changes trying to data log everything possible and not guess what had to be changed but rather know what had to be done. As Duncan would agree its a slow but rewarding process.
And we have now found that what works on one circuit is far from correct for another.
Weekend before last at wakefield the car was really quick and consistant for the power it had. But same suspension and allignment was rubbish at oran park. According to the work logs I had we made some changes and got it into the 18's but it needed lower spring rates and different bars.
The whole time the engine has been kept very tame so I can get the car right first.
With the engine on song and a transmission that doesnt reject every gear change Im not sure how quick it will go yet..
If Steve could hear it come onto the straight im sure he would have heard my gearbox crying every shift it had to do.
I have some ideas of how quick it will be judging from sector times at wakefield and south circuit. We've done plenty of testing there and had some really fast and some really slow laps. New tires will be fitted for the next outing though.
Seems a lot of us skyline people play with all other makes of cars too. So here's my project.
What started life as a 1966 vw beetle is now pretty much entirely custom. The footprint (wheelbase and track) are the same as a 1994 porsche 968 turbo which is also where the front and rear suspension are from. Steering is 924, transmission is 930 axels are 911 and everything else in between is custom. The dash and floor linings are carbon fiber as are some of the exterior panels. Brakes are 968 4 spot brembo's all round, Wheels are 996 twin turbo with RE55 semis in 18x8 and 18x10. Shocks are honda civic tein super streets.
The engine is a custom air, oil and water cooled beast with a massive increase in displacement and a pair of trust T517'z. Dry sumped, intercooled and all the other crap you do to make it fast and strong. The goal is to have fun at drag and motorkarna days.
The colour is called atlas grey and is a careera GT colour. Its still a few months off completion. Cylinder heads are still being manufactured in the US so hopefully not too much longer.
Edited by Vspec R33
Yeah Brad time for a new gearbox. Was hard to hear at times over my old wastegate (love that sound the s15 makes, almost as much as the GTR's fuel system)
Wow, what a cool beetle! What sort of things are you building it for?
Motorkarna and drags, and the occasional sunday drive.
I checked the times from that natsoft site n i did 4 sessions, so 20 laps and they reckon i totalled 10? i dun get it....that and i felt my car was handling that much better in the last session i went out but now ill never kno if it went any quicker...
what sort of bracing is required to keep the rigidity when doing this?? is it riveted or glued in??
cheers
Linton
Hey Linton, it's only on top of the current metalwork as I wanted to keep the original tank and it would have been too costly/time consuming to chop it out and redesign it. It's more just a handy mounting area for the fuel setup and the easiest way to section off the fuel from the cabin for CAMS
That is an AWESOME VW mate, absolutley love it! Be sure to put up some more pics when she's done :)
man it looks awesome! even better than you described it to me. :) it is going to be absolutely mental when it's finished. amazing.
You were there and didnt even call in to say hi Steve? :)
Cool VW!!!!
sideways - is that Chris? I met you at EC - I was in the grey r33!
Now got the hairdresser mobile! :)
Hey nice job on the beetle.. my friend has a nice bug who you might know if you post on vw forums. West side mufflers beetle?
i really like what you've done with suspension. his is more for straight line business...
Yeah Chris i was there, came down for a bit at the end of the day to say hi cause it was enjoyable watching you lot go round and round from the grandstand :( But i spotted you, Ando, Clapa and someone else all leaving as i was driving down from the grandstand
Yep I know of Westi's car. His radical approach to weight reduction has the car down to something in the 600kg range including driver from memory. The first time ive ever seen someone take weight reduction so far as to make their own brake, clutch and acelerator pedals. He is a certified mad man!
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
