Thanks all! I can't take credit though, my mechanic Sam made it all up and did a great job of it.
Richard, I ended up having the box made up by a friend of 'Craved' on here. Sam ( www.drdrift.com.au ) did all the other work with the hard lines etc
Mate, I would have loved to have had it bought off the shelf, would have saved some headaches! It was all custom built.
I think there may be a market for a pre-fabbed CAMS approved kit like that though
marlin - you need to mate, both the shitters are keeping a knock off 400r and your rival 32 gtst company at the moment!
roy - for tarmac and circuit events the e2 and 3 boxes aren't too bad unless you're dragging. there are a number of beefing up options too that wouldn't break the bank. apparently the boxes get a bad name from guys doing engine swaps into local cars and having the weak local gsr 'box fitted up.
the 4g63 engines go forever, much like sr20s and rb20s etc. for the 4g63 there are plenty of cost effective 2.2 and 2.4 kits too... when i priced a 2.4 rebuild a while back it was only $170 extra to got 2.4 over 2.0 using a factory crank (assuming you'd replace the standard crank).
the pre-e4 diffs in gsr and rs are strong enough for just anything (unlike evo 4 onwards ayc (gsr) units). the gsr spec e1-e3 use an open front centre and are best to be swapped over to ralliart helical front centre found in the rs.
if you wana prepped one i'm considering options on this one and happy to set it up to a spec requested... wont be after big dollars for it either.
boz22n - nup, csc/bmax are grooved that way, zoom in on the veins
there are a few manufacturers doing this, i got confused when fitting mine also, but definately run that way.
Ben are those rotors on back to front or and i looking at it wrong?
The car looks sweet Chris.
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
