good luck with the build Noddy....I'd love to pull the engine out after 3 years to check it was OK lol.
as for the harnesses, I use rollcage for 2 rear points, factory seatbelt points for rear 2 and have put an eyelet with reinforced plate in the floor at the correct location for points 5 and 6. Factory points are great you know they have been comprehensively engineered and tested.
Well, this can only be my relative uneducated opinion in these matters but, the hone still looks excellent, still need to check for roundness of the holes.
Cams look pretty good. The grind marks are just bedded in on the tips. I will be sending the head off for a birthday next week and let them mic it all up.
If my old machinist was still with us (RIP) he would probably be asking me why on earth I pulled it apart?...... but in more colourful language.
Edited by Noddy
New addition to the little car that could, 34 wheels and Yoki AO50 in 265/35 :) :)
I purchased GTR gaurds and indicators to allow the fitment, but they seem to fit ok without them.
Got a day at Lakeside this sunday for Make a Wish Foundation, so hopefully get to test it out and give some kids a buzz at the same time! :(
Looks the goods Ben, and it's nice you'll be giving some kids something to smile about mate. Good work ;)
Had the part-time track car tuned yesterday, pretty happy with the results for the outlay. Only mod is a turbo back exhaust.
Fark, what with another GTSt that i like the look of more then mine....depressing :D
bah, its just another GTR wannabe ;)
does look good with the 34 wheels. and I'm sure it will go good with the A050s too. I'm gonna have to fork out for a decent set of tyres next year to try and catch up
Yeah, just a APS turbo back exhaust and a reflash by RE Customs here in Vic. The mid range gain is phenomenal, really happy with it.
Just got a harness bar as well, so now I need to pick up a seat rail so I can swap the Recaro between the 180 and STi and it should be a nice occasional track jigger ;)
Not for Targa Roy, Weds will be back on. More sidewall I think will equal better handling bumpy stuff and of course there's a saving of around 3kg per corner with the Weds.
I got the 18's simply to utilise stocks of used A050's for all the circuit stuff I do. Spend a little to save a lot :D
Very nice improvement Dane ;)
Yeah it is Greg, it's an awesome street car. I haven't been in pretty much anything that would keep with it on a tight course, or at least it feels that way! :laugh:
I got it second hand off a guy from the Rex club, but he got it from Meridian. Directly from them is pretty pricey, so I've been looking for a used one for a little while now nd just got lucky.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
