my project is nearly complete.
engine has just undergone a rebuild and in addition ive added a GTR plenum with ITB to a rb25de+t
ill do a write up once its completed and tuned.
nice!
i'm also running gtr plenum on rb25det, one of the best mods i have done responds in amazing
Here our quick 6 month build going on 5 years. Hopefully finish it next year. It's a dirt circuit open wheeler powered by a 1jz. It will hopefully weigh 800 kg and make 400 hp to be competitive. Our racing is open so anything goes. We are going to run a venturi under the car and also GP style push rod suspension. If Anyone is SA keen to build a car like this or a saloon check out www.dirtcircuitsa.com. We are currently building a new track approx 85 km from Adelaide and it only costs $10 to come and race.
Cheers
Matt
http://i133.photobucket.com/albums/q60/D_S...it/Image288.jpg
http://i346.photobucket.com/albums/p405/GR...arjuly09005.jpg
http://i346.photobucket.com/albums/p405/GR...CNC/finalrc.jpg
http://i346.photobucket.com/albums/p405/GR...carfinalfeb.jpg
Edited by GROWLY CUSTOM CNC
Cheers
Matt
Here's a video of the open wheeler class :-
Well seems my car is back in one piece...now to find a garage for a few days and bolt all the goodies back on and then go start blowing stuff up again :wub: 2010 is looking like it could be a decent year of motorsport provided i can stay in the country...
What i really want is a 993 GT2
Yeah it's pretty damn cool looking isn't it Chris! It's a shame I'll be covering it in HPC coating...
That's a pic of Ian's (Juggernaut1) Full Race manifold, and I've just ordered the same one along with dual 38mm Tial wastegates and a twin scroll 3071R turbo to go onto the 180. Should give me a really responsive 300rwkw's or so, can't wait to get it on :)
how many laps till an sr flies to pieces at 300rwkw? or arn't you going to rev it?
16 or so.
mine has 15 laps of OP under it's belt at 285ish so i expect a bang next time i cross a start/finish line
Them's fighting words Troy! It's on like Donkey Kong... though the nuffer behind the wheel of the 180 might let the team down :D
2.4 hey? Sounds nice! What turbo are you running with it, the 25G?
There is some uncertainty at the moment with work so i dont know if i am back OS soon or hanging around so for the time being its same old same old std RB20 and 20G. But yeh, if the crank, pistons, rods, solid lifters, cams, springs, plenum, 25G, RB25 gearbox, new cooling setup and new fuel setup ever get installed my car should be a fair bit quicker :)
Still have to blow up the std motor though :ninja:
But....But....If you do all that it wont be an rb20 anymore......
Oh and have you taken that bloody GTR wing off yet?
