my project is nearly complete.
engine has just undergone a rebuild and in addition ive added a GTR plenum with ITB to a rb25de+t
ill do a write up once its completed and tuned.
nice!
i'm also running gtr plenum on rb25det, one of the best mods i have done responds in amazing
Here our quick 6 month build going on 5 years. Hopefully finish it next year. It's a dirt circuit open wheeler powered by a 1jz. It will hopefully weigh 800 kg and make 400 hp to be competitive. Our racing is open so anything goes. We are going to run a venturi under the car and also GP style push rod suspension. If Anyone is SA keen to build a car like this or a saloon check out www.dirtcircuitsa.com. We are currently building a new track approx 85 km from Adelaide and it only costs $10 to come and race.
Cheers
Matt
http://i133.photobucket.com/albums/q60/D_S...it/Image288.jpg
http://i346.photobucket.com/albums/p405/GR...arjuly09005.jpg
http://i346.photobucket.com/albums/p405/GR...CNC/finalrc.jpg
http://i346.photobucket.com/albums/p405/GR...carfinalfeb.jpg
Edited by GROWLY CUSTOM CNC
Cheers
Matt
Here's a video of the open wheeler class :-
Well seems my car is back in one piece...now to find a garage for a few days and bolt all the goodies back on and then go start blowing stuff up again :wub: 2010 is looking like it could be a decent year of motorsport provided i can stay in the country...
What i really want is a 993 GT2
Yeah it's pretty damn cool looking isn't it Chris! It's a shame I'll be covering it in HPC coating...
That's a pic of Ian's (Juggernaut1) Full Race manifold, and I've just ordered the same one along with dual 38mm Tial wastegates and a twin scroll 3071R turbo to go onto the 180. Should give me a really responsive 300rwkw's or so, can't wait to get it on :)
how many laps till an sr flies to pieces at 300rwkw? or arn't you going to rev it?
16 or so.
mine has 15 laps of OP under it's belt at 285ish so i expect a bang next time i cross a start/finish line
Them's fighting words Troy! It's on like Donkey Kong... though the nuffer behind the wheel of the 180 might let the team down :D
2.4 hey? Sounds nice! What turbo are you running with it, the 25G?
There is some uncertainty at the moment with work so i dont know if i am back OS soon or hanging around so for the time being its same old same old std RB20 and 20G. But yeh, if the crank, pistons, rods, solid lifters, cams, springs, plenum, 25G, RB25 gearbox, new cooling setup and new fuel setup ever get installed my car should be a fair bit quicker :)
Still have to blow up the std motor though :ninja:
But....But....If you do all that it wont be an rb20 anymore......
Oh and have you taken that bloody GTR wing off yet?
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
