my project is nearly complete.
engine has just undergone a rebuild and in addition ive added a GTR plenum with ITB to a rb25de+t
ill do a write up once its completed and tuned.
nice!
i'm also running gtr plenum on rb25det, one of the best mods i have done responds in amazing
Here our quick 6 month build going on 5 years. Hopefully finish it next year. It's a dirt circuit open wheeler powered by a 1jz. It will hopefully weigh 800 kg and make 400 hp to be competitive. Our racing is open so anything goes. We are going to run a venturi under the car and also GP style push rod suspension. If Anyone is SA keen to build a car like this or a saloon check out www.dirtcircuitsa.com. We are currently building a new track approx 85 km from Adelaide and it only costs $10 to come and race.
Cheers
Matt
http://i133.photobucket.com/albums/q60/D_S...it/Image288.jpg
http://i346.photobucket.com/albums/p405/GR...arjuly09005.jpg
http://i346.photobucket.com/albums/p405/GR...CNC/finalrc.jpg
http://i346.photobucket.com/albums/p405/GR...carfinalfeb.jpg
Edited by GROWLY CUSTOM CNC
Cheers
Matt
Here's a video of the open wheeler class :-
Well seems my car is back in one piece...now to find a garage for a few days and bolt all the goodies back on and then go start blowing stuff up again :wub: 2010 is looking like it could be a decent year of motorsport provided i can stay in the country...
What i really want is a 993 GT2
Yeah it's pretty damn cool looking isn't it Chris! It's a shame I'll be covering it in HPC coating...
That's a pic of Ian's (Juggernaut1) Full Race manifold, and I've just ordered the same one along with dual 38mm Tial wastegates and a twin scroll 3071R turbo to go onto the 180. Should give me a really responsive 300rwkw's or so, can't wait to get it on :)
how many laps till an sr flies to pieces at 300rwkw? or arn't you going to rev it?
16 or so.
mine has 15 laps of OP under it's belt at 285ish so i expect a bang next time i cross a start/finish line
Them's fighting words Troy! It's on like Donkey Kong... though the nuffer behind the wheel of the 180 might let the team down :D
2.4 hey? Sounds nice! What turbo are you running with it, the 25G?
There is some uncertainty at the moment with work so i dont know if i am back OS soon or hanging around so for the time being its same old same old std RB20 and 20G. But yeh, if the crank, pistons, rods, solid lifters, cams, springs, plenum, 25G, RB25 gearbox, new cooling setup and new fuel setup ever get installed my car should be a fair bit quicker :)
Still have to blow up the std motor though :ninja:
But....But....If you do all that it wont be an rb20 anymore......
Oh and have you taken that bloody GTR wing off yet?
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
