We need to start a thread about common problems so we are aware of them when they arise.
Does any one know of any common problems with these vehicles?? E.G. TRANSMISSION, ENGINE, A/C, ELECTRONICS ......
I Don't know if you guys have had the problem, but i have read forums in the U.S. where oil consumption with some g35 and mostly 6mt, seems to be a real issue. Infinity if pushed, has replaced engines.
Does anyone know for sure if the g35 is made in Japan or the U.S. because i was told this was a U.S. problem?
What do u do if the key fails?? how do u get in the car?
Oh and has anyone found a workshop maunal online?
If I am correctly thinking of the manual you are talking about, there is one on www.g35drive.com. http://g35driver.com/forums/showthread.php?t=107032.
awesome thanks mate... also when u pulled ur ket apart was there a metal piece floating around freely... i couldnt for the life of me work out where it was supposed to go so i left it out my key has double the range it used too...
My drivers side power window switch is starting to work only when it wants...
You will need to replace your window electric motor available from Nissan @ approx $350
I've had to replace both now
They also seem to have issues with clicking rear wheels
Welcome.
lol, nah, I didn't have anything like that. But hey, as long as it works, and it seems it works even better now, haha. My range isn't very long, so wouldn't mind the double...
What you mean clicking rear wheels? What is the actual problem?
I am having problems again with my central locking and power window both on the driver's side. The auto electrician who knows the V35 repacked the power window motor and aligned the gears and it worked for a while but has now shit itself again.
Any clues why both have gone - do they use the same controller? Are the motors for both the same as the 350Z?
The window is locked in the up position and it interfers with the top moulding when closed because the release memory for the window to open and close the door is also not operating. Any clues as to what's happening??
Unfortunately seems to be quite a common problem. A few of the 350z guys have reconditioned the power window motor but also didn't last long so they just go out and buy new motors. Best price I've seen is $500 for both passanger and drivers side. Not sure why it would interfere with the central locking though.
Here ya go Dave
http://www.infinitihelp.com/Ownership/Bull...5/ITB05-002.htm
Main page for any other problems
http://www.infinitihelp.com/Ownership/Infi...35/Diagnose.htm
Cheers
Chris
  • 1 month later...
I've been searching for info on V35's to replace my ageing POS 1994 Maxima.
Window failure in a Nissan again! I thought they fixed this problem, how the hell do they manage to replicate it again? :P
The window motors in the Maxima have been replaced by an auto elec, after Nissan charged me $200 just to look at the car. All up has cost me $500+ and they still don't work!
The back rear window is chocked up with wood, which is very stylish.
The front windows would not come back up so I reversed the polarity and used the door entry keypad to wind them back up then disconnect the power all together.
Basically I don't need to deal with this f**king bullshit again in another Nissan.
Anyone actually had someone fix the windows in the V35 and have them stay fixed before I even think about buying a V35?
Is the same problem in R33/34s or just the V35?
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is [email protected]
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
