HEY THERE GUYS JUST WONDERING ANY OFF YOU GUYS SEEN THIS SKYLINE AROUND??
I WANT TO BUY IT BUT JUST WANTED TO KNOW IF THERE IS ANYTHING ABOUT THE CAR I SHOULD KNOW ABOUT!
THRASHED??
KNOW THE OWNER?? MEMBER ON HERE??
CAR LOCATED IN RINGWOOD, IM GONNA CHECK IT OUT ON MONDAY!
THANKS GUYS!! :P
https://www.sau.com.au/forums/topic/178410-anyone-know-this-car/
this car was bought up in a topic a month ago, located in ringwood, nsw rego, perth contact phone number. we think its a scam or invalid ad... but if you gonna see it well it might not be?
did u contact the guy?
ive sent him an email, was going to ring him after i checked you guys!
i thought it looked very dodgy to begin with, $10K for a 96' GTS-t ??
but the market value of the skylines has dropped ALOT in the past year, for some reason!
so i might get a really clean, sexy, BLACK r33, or a lemon lol
anyways ill try to ring him tommorow to see if its legit, if not R34 GT-T for me then :D
is he a member on here??
thanks fellas!
$10,000 and your wondering if its dodgy?
Its plain as day its dodgy to me :D
haha like me finding a R32 GT-r with roadworthy on carsales for 10 grand, *cough* crap *cough*
http://www.carsales.com.au/used-cars/priva...|1&trecs=41
http://www.skylinesaustralia.com/forums/in...howtopic=177829
*cough*
Ps. Looks like an NSW plate in the background of one of the R33 images.
Shit same car. But why is it for sale so cheap?
I seen this car on the fourm i am pretty sure the guy was saying it was stolen from a train station.
u idiots... quick close this thread before more people jump in realising its the stolen one and quote the same thread another million times then confuse it for the R33 and think its fake cause its a R32 GTR and not a R33 GTST and then realise the computer is there enemy and then start hiding under the bed from ZE GERMANS!!!!!
OMG...
THE SKY IS FALLING...so quickly tell foxy loxy... :laughing-smiley-014:
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
