Does it have club rego or something? I spotted one when I was having lunch on the weekend in Port Melbourne a few weeks ago. It's a replica though isn't it?
Had vic trader plate on...
its a replica bought from the UK, he shipped it in. took a fair while.
  • 1 month later...
  • 2 months later...
hmm lets start with my last rental car..
lambo 560-4
(yes in SAU gear with my go-pro on it!)
then for a little diffrent
Lambo Reventón
Pagani Zonda Uno (that's a one of one and with that colour I know why)
Masarati 250F
Ferrari 599 FXX
lambo 560-4
Lambo Reventón
Masarati 250F
Ferrari 599 FXX
do you mean that all those cars were rentals or just the 560. i have about a zillion question but we'll start with, these rental cars wern't in australia were they? or were u lik an uber member of Club Corsa
Edited by alex182
no the rev, fxx and stuff were not for rent.
The place I hired the 560 had, 4 430F1, 2 430Scud, 1 430conv, 2 560-4 and 2 california's
they were meant to ahve a 458 as well which I had booked but a staff member crashed it the night b4!
so I settled for the 560.
this was over in Marenello at the ferrari factory.
So I did a tour arou nd and saw, Lambo, Ferrari, inside the pagani factory, (including them running and throwing sheets of the panels for the new zonda replacement and a private Maserati museum.
all in all a fun day.
oh and the 560, may be 500K of car but worth every cent for the noise, that said the e-gear gear box is the worse box I have ever used...just get a manual for FKs sake
the tour was done with this crowd:
Motorstars car tours
And I was blown away by the quality of the tour. Could not rate high enough.
and a few more pics of some of the toys..
Car Porn
Saw a Gallardo this afternoon driving down St Kilda Rd, then turned down Roy St and went down Queens Lane. All while I was still on St Kilda Rd.
The guy gave it some beans, and I could hear it clearly from St Kilda Rd. There was some movement in my pants after that.
Spotted an nsx on middleburogh rd about 2 weeks ago... was the first one ive seen in person and it was damn sexy
I always see an NSX in sunshine right near somerville road.
It's not in good condition though.
Aston Martin Rapide in Main Street, Croydon this evening. It must have been lost :D
fairly sure i saw that driving around croydon once, with a mate in the car who said "thats going to be gone in 10 seconds if he parks it anywhere around here...."
Last night on way to work spotted a black Ferrari California on King St, Doncaster East followed by 35 GTR.
On same road about 4-5 weeks ago spotted Lamborghini Diablo, so wide!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
