Hey all,
As some of you know I missed last weekends Winton round due to an expected arrival, and I wasn't disappointed despite it happening a day later!
At 7am Sunday morning my wife gave birth to a healthy baby girl weighing in at 7lb 5oz and 52cm long. Both bubs and mum are doing well and are expected to leave hospital this Thurs. As you can imagine both my wife and I are wrapped, and even more so we now have a pidgeon pair which is more than we could've hoped for. We named her Courtney Leah.
It was a bit of a rush to get to hospital as my wife was having major contractions on the way and we arrived with only 20-30mins to spare....as a result I am almost 100% sure that I have made a donation to the state coffers :) but if I had to do it again I would given the circumstances! Anyway the doc is writing a letter on my behalf so I will see how I go.
-Ant.
post-6243-1185918464_thumb.jpg post-6243-1185918471_thumb.jpg post-6243-1185918476_thumb.jpg
https://www.sau.com.au/forums/topic/178934-expanding-pitcrew/
Thanks guys and I will pass on your wishes to Nat.
All the best for the impending birth Snowie....being so close I didn't think you would make it to WA :whistling:
Lol James...we've pretty much decided that this is our quota so a procedure is imminent,after that I won't have to worry about keeping it in my pants....and depending who is going under the knife I may not have that urge to hump visitors legs anymore :)
Hehehe Scott....thats what cousins are for and the plus side is you don't have to clothe and feed them >_<
Cheers Paul....be sure to point Lauren in the direction of the thread so she can see the new arrival.
aww so cute!!
Zach looks like a very happy big brother >_<
My best wishes to you & your family.
So it looks like you won't be getting any more than about 4 hrs sleep for a while :)
Don't do anything drastic, I bet you'll change your mind in a few years when they're a bit older and annoy you constantly, and you wish they were cute, quiet little babies again. :whistling:
Lol....thanks guys.
congrats mate. time to get those pit crew jackets mits and boots made up.
Hahaha are you offering to knit them :(
so did you take the GTR to the hospital... haha 7,000rpm clutch dump into the hospital car park to handbrake turn in the ambulance driveway was totally necessary officer lol
While I did consider that for a sec the fact that leather is easier to clean than cloth (in regard to the passenger seat) and Nat would've had to wait until I had warmed her up didn't go in the R's favour :)
Only i think Brisberella would have been a beautiful name for a little girl.
Now thats a name....where were you when Nat and I were trying to decide on names?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
