Hey all,
As some of you know I missed last weekends Winton round due to an expected arrival, and I wasn't disappointed despite it happening a day later!
At 7am Sunday morning my wife gave birth to a healthy baby girl weighing in at 7lb 5oz and 52cm long. Both bubs and mum are doing well and are expected to leave hospital this Thurs. As you can imagine both my wife and I are wrapped, and even more so we now have a pidgeon pair which is more than we could've hoped for. We named her Courtney Leah.
It was a bit of a rush to get to hospital as my wife was having major contractions on the way and we arrived with only 20-30mins to spare....as a result I am almost 100% sure that I have made a donation to the state coffers :) but if I had to do it again I would given the circumstances! Anyway the doc is writing a letter on my behalf so I will see how I go.
-Ant.
post-6243-1185918464_thumb.jpg post-6243-1185918471_thumb.jpg post-6243-1185918476_thumb.jpg
https://www.sau.com.au/forums/topic/178934-expanding-pitcrew/
Thanks guys and I will pass on your wishes to Nat.
All the best for the impending birth Snowie....being so close I didn't think you would make it to WA :whistling:
Lol James...we've pretty much decided that this is our quota so a procedure is imminent,after that I won't have to worry about keeping it in my pants....and depending who is going under the knife I may not have that urge to hump visitors legs anymore :)
Hehehe Scott....thats what cousins are for and the plus side is you don't have to clothe and feed them >_<
Cheers Paul....be sure to point Lauren in the direction of the thread so she can see the new arrival.
aww so cute!!
Zach looks like a very happy big brother >_<
My best wishes to you & your family.
So it looks like you won't be getting any more than about 4 hrs sleep for a while :)
Don't do anything drastic, I bet you'll change your mind in a few years when they're a bit older and annoy you constantly, and you wish they were cute, quiet little babies again. :whistling:
Lol....thanks guys.
congrats mate. time to get those pit crew jackets mits and boots made up.
Hahaha are you offering to knit them :(
so did you take the GTR to the hospital... haha 7,000rpm clutch dump into the hospital car park to handbrake turn in the ambulance driveway was totally necessary officer lol
While I did consider that for a sec the fact that leather is easier to clean than cloth (in regard to the passenger seat) and Nat would've had to wait until I had warmed her up didn't go in the R's favour :)
Only i think Brisberella would have been a beautiful name for a little girl.
Now thats a name....where were you when Nat and I were trying to decide on names?
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
