  • Replies 47
It was a real GTS-R a long, long time ago. The only thing GTS-R left on it is the paint colour and the interior.
It has the build plate and all the other select distinctive parts you wont find on GTS/GTS-X.
That fact the Japs changed the motor out in the 90's is beyond my help. I just changed from 25 to a 26 for legalities sake
So saying mine is less of a GTS-R than yours… its just... a little stupid dont you think?
We all know he took a pintara and welded 2 doors shut :)
I was waiting for the Pintara comment Rossco, you’re a bit slow!
The exhaust was looking good to. Its sad that there are cobwebs on the wheels and brakes. Be good to see it get back out there...though with the EPA i would had hoped you had gone back to RB20. Fancy an R31 GTSR with an RB26 :)
I'd have less of a chance to pass the EPA with the RB20.
If i want the setup/power i want, RB26 is the only way!
As for power wise, see what happens at this stage :)
https://www.sau.com.au/forums/topic/180414-finally/page/2/#findComment-3282184
Sorry Ash. Car envy brings out the bad in me. If i could find a neat and tidy R31 GTSR i would buy it over an R32/33/34 TR anyday. They are hell cool. If it happened to havea n almight RB26 in it then all the better.
https://www.sau.com.au/forums/topic/180414-finally/page/2/#findComment-3282198
Hmmmm colors.....
Definite nomination for photo of the year (even if it has been modified slightly).
Stop taking photos of other people's engines Ash and post your own! Without exterior shots, your photo is about as much proof of a semi-completed car as Bush had of Iraq having WOMD :)
https://www.sau.com.au/forums/topic/180414-finally/page/2/#findComment-3282964
I loved the orange! Was a farken hot colour, and a good job aswell.
But it just didnt meld to the engine bay colour :cheers:
I havent even seen your engine bay - but its not the same colour, i know that colour if its the one that's been used on a couple of cars now :P
https://www.sau.com.au/forums/topic/180414-finally/page/2/#findComment-3283122
bah that orange was spew and about 10 years ago... I don't care what colour your engine bay is :)
Mine isn't the same as chris's - his is the same colour as my wheels, mine was done already when i got the car 4 years ago.... it's very similar to yours... but being a few years old there are a few chips and stuff on the paint...
https://www.sau.com.au/forums/topic/180414-finally/page/2/#findComment-3283385
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
