  • Replies 213
14 Members: Russman, sneekee, acsplit, TurboX, Stu-RS, Swink33, NYLATE, rexdan, Budge, GTS-T_Sedan, deafwish, tjandriesen, Roy, sammus
Looks like we're all waiting on results!
Nope...pics! :P
Results will be Handbags, Scotchfinger, Snowcone and Daz in no particular order for the top 4. So with that out of the way...where are the pics that will make ppl blush :)
Hey Groovers,
DECA was totally awesome!! You guys rock! The best fun you can have with ya clothes on i reckon. It was my first time down to DECA and hopefully not the last for me and the mrs. The drive home to the Central Coast NSW (about an hour and a bit north of Sydney) sucked arse, but I'll certainly make the trek down again if i get a spot at the next one. Without a doubt one of the best weekends I've had in a long time. See you all at the next one!!
Cheers again guys
Cant wait to check the results and pics!
Ok here's a strange question:
Over the weekend i was talking to someone about highflowing injectors - pretty sure it was at the cabins but not 100% sure. Who was it? I wouldnt mind talking to the highflowing guy :P
Nope...pics! :P
Personally I don't care who won so much as to see how my times stacked up...
Sarah and I had awesome day..cbf'd staying up for the weekend but maybe next time.
Thanks to all the peeps that make it happen.
Got some decent pics that I handpicked out from lot that we took..uploading now..
here's one vid i put together of myself, snowy, ferni and john picture in picture for some shits and giggles!
deca 4-in-1 first course
Thats very cool mate!
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
