  • Replies 83
Originally posted by Nexus_SiX
Grand total of :269.8RWHP
This was achieved with a pod; "bush airbox"; 3" from turbo with exhaust wrap and a Power FC
Not forgeting the BOV and 2 SAU stickers
Nice to meet ya too btw.
Originally posted by Steve-SST
We need to Dyno test these stickers.
You'll have a tough time. Theyre pretty bloody impossible to come across, hey memphis?
If you'd listened to me I could have saved you $25
Originally posted by S13_Angel
PSI GTSII: huh??
I told ya before ya put it on the dyno it'd do 230rwHP;)
I am also quite talented with a 'Crayola Caddy' and could have knocked you up a great dyno graph to:p
Not sure how much credability it would have held though:rolleyes: :D
zanda lol @ 13.1 on stock turbo. not unless your running 20psi
My old Red top T25G SR20 did 228rwHP on 13.3psi.....and ran a low/mid 13 on this setup....with a good 60ft Its 'do able';)
Nice result Matty
must be a nice streetable package now - swap you a drive when I get back from OS.
Thanks Gav - yeah it's not too bad - the tuning is the secret.
No worries with swapping the drive, hey, if ya need me to look after the R whilst you are away, just drop me a line!
:uh-huh:
Ohh calm down, I slept in and didnt have time to drop in at the office!
But i do have a heap of them ready to be dropped off at works auto
Also, I hate to see what my car would have got without my 3x SAU stickers :uhh:
nice to see u all - dont think ive seen so many skylines in one place haha. I was too wussie to put my car on - its nothing to get real excited about anyway.
But good job guys must admit there was some surprises in there as well ;)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
