probably not a super car to you guys but spotted a black lotus esprit s4 the other nite @ sandgate supercheap, ive loved these things since i was a kid.
Nice! I've loved them since I was a kid too.
Thats a GT3RS, a VERY special porka :)
Spotted red with white racing stripe FORD GT (not the Falcon GT) on Friday night along Phillip St in the CBD.
SuperCarClub's one no doubt, not like there's heaps of them getting around
Twin turbo 3.5L V8. Yum.
If you havnt been in one, they're worth the wait. They sound SO good even just on idle
Wouldn't know if you'd call it a supercar but I spotted a silver Rolls Royce Phantom on the way to work thismorning. Was at Yanko Road in Pymble
Had silver plates i think. Started with J...
prolly 'JASA'. that must have some kays on it- see it driving all the time
Forgot to mention I saw this a few weeks ago on Georges River Road in Croydon Park.
It's the latest (current) version AMG C63, and yes, that is a green P-plate in the rear window! Lucky mo-fo...
Spotted a brand new red ferrari of some descript, have seen it in the same place twice now...
Except last night, a bus decided to ignore its stop sign and try and cram itself infront of me and behind the ferrari... both of us were doing about 50kph, I had to slam on the brakes or get taken out by a bus, I made my choice. The Ferrari managed to get by unscathed, but damn it was close!
f**k bus drivers, that's the second time that has happened to me at that exact spot... if it happens again, I'm just going to let them hit me and call the cops so the c*nt can lose his license and all his passangers can be late!
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
