Hi all. As topic states.
Car: R32 gtst RB20DET.. stock clutch, gearbox etc.
Problem: Shifting is not a problem. However, when i quickly clutch in and put it to first (when the car is stationary) it sometimes crunches.. though the frequency is getting alot higher.
To be safe, I have to slowly step on the clutch ALL the way down to the bottom. AND THEN and only then can I engage first gear.
It happens in situations for example: When your sitting at the lights and then all of a sudden the lights change to green. I quickly try to gear in to first and it crunches. It slowly eats a little of my heart out each time i hear/feel it crunch my gears.
What could it be?
Thanks in advance, Ben.
https://www.sau.com.au/forums/topic/183796-crunching-first-gear/
I was thinking it was more to do with the clutch.. because when i clutch in first then engage the gear it feels like the clutch hasnt fully engaged yet.
I've had previous problems with my clutch before. Last time the slave cylinder blew and when i got it replaced, the mechanic didnt bleed it in properly and it was slipping like hell.. he sorted that out.. but yeah..
maybe bubbles in my clutch line?
from what ive read, first gear doesnt have syncro's (hence you cant shift into it whilst rolling, unless you rev-match)
My one acts similar, it doesnt slide into 1st gear when stationary, i feel a resistance, notchy but no actual grinding.
I'll be replacing my clutch in a couple weeks time, so can comment then if i have a change in shifting etc
well yeah.. that kinda doesn't really solve my problem.
My problem now is crunching when quickly gearing into first: at times for example when i'm at the lights and it suddenly goes green. If I gear in slowly i.e. clutch in all the way to the bottom (slowly) then engage first theres usually no problem.
From what I feel, it feels as though when i quickly step on the clutch pedal, the actually mechanisms (after the clutch pedal) are laggy in engaging the clutch. like the clutch itself has a slower reaction time into actually engaging.. For example if you were to as quickly as possible step on the clutch pedal. I.e. STAMP on it and then chuck it into first gear it will definitely crunch. Which brings me to question whether or not there are bubbles in my clutch lines/reservoir.
How can you check for bubbles? I've tried getting someone to pump the clutch while i open the lid of the reservoir and see if theres any bubbles or anything.. (no avail)
Blah.. hard to explain i guess.. if i figure this out i'll post up a proper explanation/solution.
Edited by chinkeboi
Since when ????
Not since 1970s. My family's 1968 Falcon had synchro on first.
chinkeboi, why don't you keep an eye on the lights so you can be in first gear when they change?
Since when ????
Lol.. thats not really the point man, however bliss ignorance is.. something is wrong with the car and i want to try and ATLEAST source the problem. as for me being alert at the lights thats no problems..
I'm getting the gearbox oil changed next service and i'll let u know if that helps or not
give the clutch fluid a good flushing. and dont slam it into gear :S even if the light goes green, only takes a extra 1-2seconds to wait for the clutch to engage... or upgrade ur clutch and pressure plate so it grabs sooner/faster/harder....
I found this, hope it may help;
Service Information - Bulletin Number 23 01 99
SUBJECT: Manual Transmission Difficult to Shift - Diagnostic Tips
MODEL: All with Manual Transmission
SITUATION: Transmission may be difficult to shift especially first gear
engagement and/or gear shift linkage is binding. Note: Field observations
have indicated that a transmission which is difficult to shift (especially
into first gear) is primarily a clutch related problem and only in isolated
cases a failure in the transmission itself.
PROCEDURE:
Verify the customer complaint:
Note: Engage the parking brake and assure that no people or objects are in
the vehicle's path.
- - Run the engine at idle speed
- - Press the clutch pedal to the floor
- - From the neutral stick shift position engage first gear
If first gear is difficult to engage, hold the stick shift at the
resistance point (approximately half of the total stick shift travel) with
constant force.
Then switch the ignition off with the other hand.
DIAGNOSIS 1:
If first gear now engages completely, i.e. the stick shift moves to the end
position without any additional pressure applied, there is a problem in the
clutch system.
Explanation:
Because the clutch does not uncouple completely, a residual torque is
transmitted to the transmission input shaft when the engine is running.
This inhibits the release and meshing of the sliding sleeve, in the
transmission, at the end of the synchronization process. Turning the
engine off relieves the input shaft of this torque thus simulating a
completely uncoupled clutch.
DIAGNOSIS 2:
If the stick shift remains at the resistance point, there is a problem in
the external gear shift linkage or in the transmission.
CAUSE:
DIAGNOSIS 1:
Possible causes for a clutch problem as per Diagnosis 1 above are:
- - Input shaft taper splines not lubricated properly/grease dried out.
- - Clutch disc difficult to move on transmission input shaft.
- - Clutch disc wobble.
- - Air in the hydraulic system of clutch mechanism.
- - Release bearing defective or difficult to move on the guide sleeve.
- - Clutch disc or pressure plate broken/worn out.
DIAGNOSIS 2:
Possible causes for gear shift linkage binding and/or internal transmission
problems as per Diagnosis 2 above:
- - External gearshift linkage binding (shift rod joints stiff).
- - Stick shift bellows boot incorrectly installed (positioned too high or
too low on the stick shift lever).
- - Sound deadening between the outer gear shift linkage and the body
incorrectly installed and/or distorted.
Possible causes inside of the transmission:
- - Faulty synchronization.
- - Internal gear shift linkage binding.
- - Water in the transmission fluid. (rare)
yeah. if it does it when its not moving then yes. its a clutch issue. and now its f**ked the synchro and selector sleeve on 1st. so you will have to just put up with it till you get a new clutch.
you do let it rest for a few seconds before you put it in gear? if not thats relativly normal if you just foot on clutch and bang it in gear.
if you put your ear on the shifer while its running you can here it spinning. put the clutch in and you should hear it slow down and stop. that time is how long you should wait till you put it in gear to avoid crunching
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
