http://www.ebay.com.au/itm/Nissan-Stagea-M35-2003-/190572257997?pt=AU_Cars&hash=item2c5efde2cd
Does anyone know about this car?
any idea why its so cheap?
im going to say its stuffed but does anyone actually know?
He's had cruise control fitted since the first picture (unless that wasn't his interior in that pic). My guess is he may have an airbag light or something like that, hence not selling with a roadworthy cert.
It's probably good value at $8k.
Adrian - I told you on Wednesday night - buy Aaron's....... :thumbsup:
nice m35 for sale on yahoo jp
Modded M35 yahoo Jp
Nice! HKS Vpro, Racing seat - gauges everywhere, Nitrous system. And suffering the dreaded Airbag light by the look of it!
Looks like a pretty serious set up - and details about power / 1/4 mile?
For those who have removed a radiator from a M35.. the AC condenser, does it come out with the radiator?
Also, the fan on the front of the condenser, does this need to be removed? It looks as though it has plastic mounts that go through the AC condenser AND the radiator. Do I just pull these out?
the condenser wont come out unless you remove it from the AC system, and youll need to vent the gas.
its easy enough to just move it out of the way, youll need to remove the engine fan and shroud to do that.
if you have a fan with the little plastic holders, does it have an FMIC? thats the only reason why it would need to be replaced.
anyway yes just pull them out, if they break, youll need to get some more.
There is a vid on youtube of him tracking it.
Wasn't very impressive IMO (not that mine is lol)
Can't be too serious... he still has the stock suction pipe!
Yep got the two bolts in the top. The condenser just wanted to stay put with the radiator. Got a little stubby screwdriver and gave it a smack a few times to push the condensor out of the mounts at the base of the radiator.
Radiator is out with the fan on but the new unit looks 3x as thick. Not sure how I'll go getting the fan back on after installing the new radiator if I do go down that path..
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
