I never ran the single Walbro (I modified the pump housing to fit a Tomei gtr pump) because I listened to the heresay in the forced induction section. I have since changed my tune with regards to them. For all but the highest pressure setups Walbro's work and fit perfectly. Any more flow will require a complete fuel system upgrade.
Save your cash and time and fit what works, but you will still need to rewire the power to the pump with a relay.
I think Cam was hoping to save a buck and run the factory pump. Of course if it cant supply the fuel he needs there will be another tune on the cards which will negate any savings.
I don't think we did this on mine. Seems to be running ok? Am I going to hit fuel cut down the track?
Actually no, I wanted to see what we could get out of a plug and play ECU with stock fuelling.
I'm thinking slightly differently and thinking I should do injectors and fuel pump before the tune.
Is the pump body in the M35 the same as the V35/G35/350Z?
The filter is the same....the body ain't....we have a return system.
Not a bad idea to do injectors and fuel pump first....IMO there is no way you will max out the standard fuel system with the stock turbo/boost even with dump exhaust and SP ect!
Edited by Jetwreck
Probably, but my plan is to get the supporting mods in place then do the turbo. But if it can be tuned to stop maxing out the injectors at least i know i dont have to hurry.
Is our pump body the same as anything?
Just curious. Thanks for the info.
Where did you get your injectors from Scotty? Much difficulty making them fit? (I gather the Xspurt's aren't drop in, where as the Deschworks are).
I havent tried them, only the newer Bosch/ID/Xspurts are going to give you the smooth idle though. Be wary of other large injectors. I think I can get the Xspurts for around $100 each from the wholesaler, Injectors online.
Any reason you went from ID's to Xspurts?
They are the same thing, all based off bosch bodys and flow matched apparently. Mine idles better now than with the 610's in the rail. They drop in if you remove the spacers but you will have to wire/crimp the new plugs in.
Ryan, looking at this pump the sock pickup is the same as Walbro, as is the power plug. Perhaps this deatschwerks IS going to fit ok... Buy it and try?
http://www.skylinesaustralia.com/forums/topic/379042-deatschwerks-300lph-fuel-pump/
Another (interim) option is to replace the stock pressure reg with an adjustable one. I bought one for $60 & put it in today. The OEM pump is now supplying more fuel courtesy of higher pressures & I had to back the AFR's off a fair bit across the mid range. And at the top end they look pretty good now instead of a bit lean.
I haven't had enough time to tune it properly, but looking very promising so far.
Cheers Scotty. Thats what I was thinking, it looks the same as the Walbro, so does the Aeromotive, hence the question. Might organise that shortly.
Are the $60 ebay FPRs any good or do you need to spend the couple of hundred to get a Sard etc?
Be careful running much higher than stock pressure, the pump flows less and will only supply a dribble at over 80psi. What boost are you running?
Stock boost atm. Static pressure is about 52psi, but it's a rising rate FPR so should increase to about 65psi at my current boost level. I won't up the boost to more than about 16psi anyway, so this setup with stock pump & injectors could do me until I need a new turbo (providing AFR's are able to adjusted to cope with the extra 3 psi when the time comes).
Edited by Commsman
Sard would be better I think, but I didn't really know if this would work out as good as it did, so I didn't want an expensive item sitting in the shed unused. Having said that, I was impressed with the feel of mine, very solidly cut from billet aluminium. The hose clamps were crap tho...
You don't always need to buy name brands to achieve a good result.... and sometimes you do. It's just knowing when :happy:
Edited by Commsman
There's a heap of fake sard regs around so be careful. I'm using an SX reg and it's been fine.
Rising rate regs usually increase the fuel pressure double the boost so you could be up there, do you have a gauge in the dash?
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
