No bolts, just some small slots in the bottom.
I just helped Dave M35 with some info on fitting, I will just cut and paste my response.
Quote:
Yeh, I had a few issues too. The right hand twist fitting for the top I had to ditch the rubber, the pin was out a little too much. Looks like a manufacturing fault but it works ok.
The fiberglass had to be cut out around the radiator cap, not too much, just use a nice sharp blade so you can remove the cap easily. the fiberglass section must be further away on the G35.
The lower condenser slots are too wide like you said, but it doesn't seem to matter once the top bolts are done up. Just make sure the flat part sticking out stays above the slot then do the top bolts up.
The fan shroud is too short, I had to cut the edge off on the airbox side. Trial fit it before you put the rad in the car, you will see the section you need to remove.
I really like this size converter Josh: http://www.rimsntires.com/specs.jsp
Chuck in your standard wheel size and offset, and your standard tyre wheel and offset, and then throw in your new wheel size and offset.
You can then muck around with tyre size until you get something reasonably common that puts the speedo about right.
FWIW I'm running 245/40 18s on my 18x8s, but 245/45 is the better fit.
235 or maybe a 245 if you can fit it?
I'm not good on the internal clearances.... but know that space is an issue a little more stretch will give you room.
Someone else know?
Try looking at G35 sedans with the same sized wheels.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
