Would you still need an after market computer to run a high flow turbo etc? How much performance upgrade would this provide over stock?
So much fail in the description. "JDM 01-05 NISSAN STAGEA V35 M35 PM35 250RS VQ25"
I'd say the seller has no idea what they were selling. If it didn't have written on it VQ25(T) NM35, I'd say it would be too big a risk. Even so, it would still be a small risk to buy, even though it looks like it'll be right.
As for performance upgrade, it's a bit of a lucky dip. It wouldn't be tuned for all the stuff most of us are running.
^If those IMPUL units are with the concept of 'individual' tunes / per the original customer's demand (like all the Mines ECU's for skylines), definitely a lucky dip - wouldn't trust em as far as I could throw em!
I reckon it's for a vq25dd - not hard to write "(T)" in pink pen then sell it "as is"...
Christ I'm turning into a cynical old man... :O
Yep, there was some "arse covering" in that ad.
I must be cynical too...
I have done some searching and can't really find out the differences between the 250tRS FOUR V and the 250t RX FOUR..
Are there any differences in the models that are consistent, cause it seems like it's random what each model has as I browse through car sales ads!!
RS FOUR V has hicas, also non-integrated stereo. black interior, manual seats except with leather.
RX doesn't have hicas, nor can it be optioned with; will have electric seats, integrated stereo and boring beige interior.
^^ Double check if it's actually a RS Four V. My RS Four doesn't have HICAS, but I believe it was an option.
ahh yes, apologies, the V should denote hicas. however youre right, RS doesn't always have hicas.
ARX always has hicas, AXIS may have been an option, but I don't think there are enough around for us to have seen one.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
