Would you still need an after market computer to run a high flow turbo etc? How much performance upgrade would this provide over stock?
So much fail in the description. "JDM 01-05 NISSAN STAGEA V35 M35 PM35 250RS VQ25"
I'd say the seller has no idea what they were selling. If it didn't have written on it VQ25(T) NM35, I'd say it would be too big a risk. Even so, it would still be a small risk to buy, even though it looks like it'll be right.
As for performance upgrade, it's a bit of a lucky dip. It wouldn't be tuned for all the stuff most of us are running.
^If those IMPUL units are with the concept of 'individual' tunes / per the original customer's demand (like all the Mines ECU's for skylines), definitely a lucky dip - wouldn't trust em as far as I could throw em!
I reckon it's for a vq25dd - not hard to write "(T)" in pink pen then sell it "as is"...
Christ I'm turning into a cynical old man... :O
Yep, there was some "arse covering" in that ad.
I must be cynical too...
I have done some searching and can't really find out the differences between the 250tRS FOUR V and the 250t RX FOUR..
Are there any differences in the models that are consistent, cause it seems like it's random what each model has as I browse through car sales ads!!
RS FOUR V has hicas, also non-integrated stereo. black interior, manual seats except with leather.
RX doesn't have hicas, nor can it be optioned with; will have electric seats, integrated stereo and boring beige interior.
^^ Double check if it's actually a RS Four V. My RS Four doesn't have HICAS, but I believe it was an option.
ahh yes, apologies, the V should denote hicas. however youre right, RS doesn't always have hicas.
ARX always has hicas, AXIS may have been an option, but I don't think there are enough around for us to have seen one.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
