Ok i could think of 1 way ...... find a model EG series 2 r 33 ..... find people who have splities jjr yellow jackets ect ..... who have run them for around 20000 kms who are within the same power range let say 180-200 kwatw and test them with the multi meter then compair results with an adverage ?
Really? Like everything these days? Thas fascinating.
The multimeter readings won't prove much vs. real world results IMO. I dynoed my S15 track car with Splitfires and then with YJs. This is a 280rwkw car on E85 and the differences were negligible when overlayed. Where the Splitfires achieved 3kw more at one point, the YJs would be 3kw higher at another point. In fact overall I was a little happier with the YJ graph, but again it's completely negligible. Coilpacks have to provide a current...it's not like different brands of turbo where you're going to end up with dramatically different results on the dyno. They seem to either work or they don't. The only inbetweens come from wear over time, but all brands seem to carry the same time/km warranty.
^ Just expanding on one point birds alluded to, multimeter testing would require a constant problem, but when I used to have trouble with the stock coilpacks they worked inconsistently, sometimes the car would run as normal, others it'd be missing all over the place.
Thats an interesting input.... good to see they both have differance in application .... sorry i ment to describe a test for how they help up for stregth not power as in test the resistance between all................... the standard ones that i had the differance between working and missing was 1310 to 1410 it was funny to see .0100 was the diff between working and not ..... i would want to see how they all hold up for time .... how long they last
  • 3 weeks later...
So for those who've had yellow jackets fail, did they die completely or develop a missfire on high rpm boost (as per broken OEM's).
I've had mine in for about a year and just had the misfire reappear.
Mine died completely...well the car would start on 5 cylidners and take 5 minutes of warm up before the 6th one kicked in. Easy to diagnose...just swapped the coilpacks around until I found the dud.
after skimming through SAU threads relating to YJs v SFs, the common thing that gets brought up about YJs is the price difference, made in china, the odd YJ being returned and they still seem to do the job.
Im definitely keen to have this 'officially' tested to settle the argument(s) and to see the figures etc. But atm, I'm about $$$.. so YJ's will be my choice for when they need replacing.
*touch wood*
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
