  • Replies 812
I was thinking (which is dangerous)
Have you had a chance to weigh the front and rear seperatly of a R32 gtst to compare it to your ls1 powered jobbie...would be interesting to see how far the weight has gone rearward with the lighter motor but heavier box, GTR diff etc
we know that complete ls2 weighs 90kg, we weighd rb25de today and it maxed out the scales so 120kg+
SO Judging from what I remeber the weight balence is standard. you should be very damn close to 50:50 front to rear.
I cant believe how light the Ls1's are 30+ kgs lighter than an RB25de is quite suprising so that would prob be more like 50+ kgs over a DET once you include The IC + Piping etc and not to metion all that hangs right at the front of the car.
yeh it is at least 30kg as that was the max the scale would read, and it was short steer pump and exhaust manifold.
weighed r33 tubo box today and it went 57.5kg. i was very surprised as i thought it would be lighteras thats only 5kg lighter than the tremec 6 speed.
so i think i am up somewhere between 35-55 kilos in the driveline which i am very happy with.
basically this means that the car should be easier to make handle and my power to weight is up.
1000kg and 400hp is looking good.
ok, just read the whole thread..(phew!)...nicely done indeedy...now.. if someone wants a 31 or 30 to put a v8 in..call me...anytime :O
interesting on the weight differences, who'd have thunk it eh?!!!
cant wait to see full pics and vid!!!
Not too much to report, recieved coil-overs from Gary last week. just waiting for the lower arms and bars and bush kits now which should have by friday so with a bit of luck i might have the car back on the ground on saturday arvo. Also close to purchasing front brake kit, so car will be pretty much a roller again. That will just leave engine completion, which i have all the parts for, wiring & exhaust. some fiddly bits to do also like tin-work and ducting. catch-cans etc..........neverending.
yeh, eye on the prize. keep putting myself behind the 8 ball though, finish one thing then find something else to buy. looking seriously at that intake again, tuner reckons there is free horespower to be had with being able to adjust runner lengths so it looks like it will be happening next. Also going to give the E85 a go as all the race meetings are sprints so consumption wont be an issue. Doing endurance events might mean 2 extra fuel stops.
Keep the end in mind Stu!
I might come past this week to talk the sphincter of the universe about servicing the golf........will let you know
i have no doubt there is more power to be made on E85, cooler intake temps coupled with higher octane levels allowing more agressive tuning, its the consumption that is the concern as i only have a 50liter tank. but if its OK for V8SC, im sure ill be fine.
e85 is a great idea....we might give that a shot too. we've got a drain valve on the fuel cell, and datalogit to switch the tunes easily....will be good to see how it compares
lol. that is pretty cool. finally get that decent engine into a decent chassis. :P I like it.
can't wait to see your thing rumbleing along stu. it will definitely rock.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
