  • Replies 812
there are also startermotor relocation kits available now which puts the starter on the other side which would solve all the issues. if your 32 goes 1350kg, you will be 450kg lighter than a VE, trust me, you dont need to turbo it. the car turns 3rd gear for fun. the torque is massive.
found a thread on sump extensions and baffeling, going to do this before next track day.
http://www.performanceforums.com/forums/sh....php?t=67247482
That sump looks the money, bolt it up and get to wakie hehe
COOL! Thanks for posting. Its got some toe out of turn 1 when you stretched its legs. Sounds so sweet, makes more usable power then any turbo 6 would make. So in the world of crazy conversions i am torn between Chev or 20B :P (not that i will be doing either...but fun to dream)
brakes are great, they were recommended by Duncan who is a good source of info and advice for most things bar pushrod v8s lol. They easily outbtake the mechanical grip of the tyre if you jump on them. i realed off 6 laps straight, 3 of which were in the 1.08sand the rest 1.09s and they were great. its the first time ive had the confidence to climb on them hard as the car setup is improving all the time. i could cover the brake in turn 1 at 240kph without unsettling the car and easily make the turn in to turn 2, very happy. but my car is light so doesnt work them as hard.
Sounds plenty strong stu :P
How are you finding the brakes?
haha get stuffed both of you :P
good to see the times tumbling Stu....I'm sure it has a couple more seconds over the next 12 months with more development which makes this about the quickest GTST going around
ok Roy, its only a warm up lap while tuning but its ok.
Oh yeah bring on the SAUNSW day!!!
Im not kidding, so many people say it sounds like a v8supercab, and you know what? Get someone to drive it and close your eyes. You'll agree!
I finally worked out where you got the inspiration from for the colour scheme for your car - you copied one of my toys! :devil:
I built this baby from a wreck 25 years ago and have spent the last month bringing it back to life after having it in storage for 22 years. She also runs a side pipe with a very open exhaust - she makes some noise (stirs up the neighbours to no end) but it is not in the same league as your car.
In addition, Daniel's car now has a complete new front end (suspension, steering and brakes) in it and it is at the panel shop for some structual repairs. I am also in the process of picking up a full set of R33 GTR front panels (guards, bonnet and front bar) so the big question is do I make it into a Series II or a GTR. Decisions, decisions but to save 20 kg and be able to run 9's all round is very tempting........
ahh, good charles, good too see the projects are coming along. the little jeep looks great. sooner its done you can turn your attention to the track cars.
I started the oil pan/sump modifications on saturday. actually almost finished it with only some internal gates left to do and put a relief in the front fot the sway bar.
hope to have it finished this week.......then just have to swap it with the one in the car and re-plumb the cooler and external oil filter. Pretty happy so far as it only took about 4 hours.
I finally worked out where you got the inspiration from for the colour scheme for your car - you copied one of my toys! :(
ended up finding that it was rocker ratio that was the issue, not the brand so replaced the 1.8s with 1.7s.
we tried to run a group buy on custom oil pans, but had no interest. if you want one done PM me. there are pics of the rb sumps i have done on here, but like i said people were to tight to spend $550. rather rebuild engines lol.
Looking nice stu :P
Do you wanna do my 30 sump lol?
And what rockers did you replace the Yella Terra's with, I think you said Harland Sharp was a possibility
hahha, you know, they look like a horse.....
got the sump finished this arvo and back in the car tonight. re-plumbed the remote filter, cooler and oil pressure switches.
everything is sweet, fits neatly with no clearance issues. Engine now holds around 8.5 litres on a dry fill which is a great improvement over the 6 litre capacity from factory.
unfortunately on start up we found a pin hole on one of the welds around the high pressure outlet so the pan needs to come off again. I wont be doing it in the car again so going to pull the engine and put a bearing set through it while im at it.
happy that it all fits and everything is plumbed, but also dissapointed with the leak.
probably puts me out for sau track day. ;)
charles....definately gtr front....more rubber is always handy up front and it gives you the option of running same size tyres all round.
stu...what is a "rocker"??
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
