i'm looking to buy some coilovers with 12kg front and 10kg rear spring rates, has anyone here had experience with these as im interested in how stiff they would be, the coilovers also have 32 damper adjustments, so say the spring rates are too stiff, could you soften them up by using the damper adjustments, thanks in advance, the car would be mainly for street use by the way
https://www.sau.com.au/forums/topic/189780-coilovers/
  • Replies 133
Yeah depends how tolerant you are towards these kinda things.
For street use would be a bit too stiff IMO, and would make driving it daily a bit of a pain.
Not to mention if you are into hill runs and the like, a car with these will handle worse on uneven roads than stockies. The bumpiness will throw the whole car off balance as the suspension wont really absorb the bumps well.
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3419368
It's likely the shocks will not be able to cope with the huge spring rates.
also, there is virtually no way the shock can "adjust" the springing - it only adjusts the damping.
to adjust the springs, you will have to change the springs.
WAY OTT for the road.
try someting more like 6 and 4 for a GTR for road use
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3419642
Way too high, why would you want high spring rates in what is mainly a daily driver? Look into normal lowered springs, upgraded shocks and some swaybars to control the roll. Dont try and control roll with springs, especially not in a daily driver!
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3420708
Might i ask why you're looking at such high spring rates for a daily driver?
i'll agree with most of them here that you should go with lower spring rate. Especially since you're driving a GTST.
i'M not wanting to start another thread, so here goes..
1. Has anyone had any experience with Buddy Club Jr Spec Coilovers? How are they like? will be running it in a Silvia
2. I've heard/read that HKS Hipermax Performers have pretty bad shocks. Anyone able to explain furthur aside from the ride being too stiff?
3. Which would be better? Greddy Type-s Coilovers or these Buddy Club ones
Thanks
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3421953
I own a R32 GTR and just installed brand new TEIN Monoflex coilovers, they run front 7kg and rear 7kg with 32 point damper adjustment, and i can say that they are absolutely brilliant with about 4 inch of Base height adjustment to come down so that the springs stay same height.
They are still comfortable on softest setting car is shit loads more rigid with alot less body role.
Mind you i have them 3.5inches lowered rolling on 20inch rims hehe so anything smaller in rim size would be perfect also, good luck but i swear buy Tein all my mates have had them for years and tracked there cars heaps and no problems.
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3422754
im running Tein HAs ATM with s pring rate of Front: 9 and Rears : 8 and its good and dont forget its a stagea. I had the valving swapped to Oz specs by fulcrum suspension. And its firm but nice. The car feels like its stuck to the road when going on rough roads. I had the damper set to the softest on the fron and 3 clicks from the softest at the rear
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3422800
can i ask how much it was for your HA's to be revalved by fulcrum?
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3423009
  • 3 weeks later...
i've just installed some
tein circuit master type RA into my r33 with 10kg front and rear spring rate (racing springs as tein call them), i have yet to drive the car yet (due to not having a gearbox) but once i do, i will let you know what the ride is like.
i had previously had d2 coilovers which had a huge spring-rate and i found it drivable in street-condition abit bumpy and i got uses to it
Edited by [Michael]
https://www.sau.com.au/forums/topic/189780-coilovers/#findComment-3465852
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
