no need to say too much --------------->> RACEPACE +1
saw ur car at Racingline b4
how come u dont get nigel to tune the car for u???
I've retracted my post due to a particular user not appreciating my comments. If you'd like to know why I would not take my car to this tuner feel free to PM me.
  • Replies 50
i would also agree with phil & Trent for CREATD Motorsports
They modified a rb26 PFC to run in my rb20 and no dramas at all
great guys and great prices to
kthnx
What the!?!?! Modified RB26DETT pfc for your RB20DET?? How was that done? Was it complicated? How's it running now?
Have to say Ray at RE Customs, anytime for Power FC.
I have seen many cars from other "reputable" workshops with PFC and must say they either didn't have a smooth fuel or power curve and some even ran quite lean.
If you want an excellent job and not get ripped off. RE is the only place in my opinion. :nyaanyaa:
If you want an excellent job and not get ripped off. RE is the only place in my opinion. :spank:
Who would be dumb enough to tune gtrs LEAN :) ?
Haha ^
Yeah, Racepace, RE, Creatd and Chasers are all workshops worth considering with reputable tuners.
From experience Racepace is rather pricey, but he does really know his stuff.
Edited by Yawn
Which tuners lol?
A long time ago i posted something in the member's section and i got a call from THIS TUNER, must be the same tuner lol. Still give me a good laugh everytime i think about it, one sad tuner.
Electronic Automotive
03 9408-8122
15 Salicki Ave, Epping
they do tonnes of top notch cars, have been around for like 20yrs, had the donught king drift S15 in there today, they do heaps a race cars, did the rally WRX we had at work, i wouldnt take my car anywhere else, there australias king of Fuel injection....
Go Chasers.
Paul tunes rally cars in China. People from overseas pay him to fly down to their country to do tuning.
Chasers Motorworks
4/440 Dynon Rd, West Melbourne
9687 7118
I vote for Chasers. Paul really knows his GTRs...
+ 1 for paul @ chasers
The man definitely knows how to tune ANYTHING
they brought in helicopter with a subie engine and a motec m4 for him to tune the other day - he also gets flown all over asia to tune rally cars and even does motorbikes from time to time.
Chasers, Racepace, CREATD are definitley well known in the vic import scene - you can't go wrong with any of them
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
