Purple R33 GTR with SAU stickers that went into an apartment on sir fred drive near UQ and then came out later, up the street and did a U turn at the roundabout. I was one of the guys in the high vis vests doing the Traffic noise measurements across the road. Waved but My car wasn't anywhere nearby so i probably just looked like some angry uni student who was upset about his noise measurements.
Also saw a pair of white r34's coming and going around the multi story there.
Edited by sneakey pete
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
